[Qgis-user] How to use the digitize tab in layer properties in QGIS 3.4
Burghardt.Scholle at stadt.wolfsburg.de Burghardt.Scholle at stadt.wolfsburg.de
Tue Nov 6 00:50:16 PST 2018
it depends on the QGIS version you are using :-). In 3.4.0 you have to make the settings for the desired topology check, save and close the project. After reopening, the function is available. The check, however, only takes place after the digitization of the geometry element when saving. If an error is found, the panel "Geometry Validation" appears on the right. In 3.4.1 the error is fixed and no saving, closing and reopening of the project is necessary anymore.
Hope this helps.
Regards
Burghardt
> -----Ursprüngliche Nachricht-----
> Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von
> Andreas Wicht
> Gesendet: Dienstag, 6. November 2018 09:15
> An: haufe at gbd-consult.de
> Cc: qgis-user at lists.osgeo.org
> Betreff: Re: [Qgis-user] How to use the digitize tab in layer properties in QGIS
> 3.4
> Hi,
> > currently I am confused how to use the digitize tab in the layer
> > properties.
> I am experiencing the same confusion. Setting the desired parameters is
> trivial
> but I am also missing the panel shown in the gif where errors are displayed.
> Hope anybody can shine a light on this.
> Best regards
> Andreas
> Qgis-user mailing list
