[Qgis-user] Dissolve tool failing to produce outputs
Andrew Harfoot ajph at geodata.soton.ac.uk
Mon Nov 19 06:51:34 PST 2018
Just to add that the equivalent dissolve tool in 2.18.25 completes
successfully on the data.
On 19/11/2018 14:47, Andrew Harfoot wrote:
> I'm seeing very strange behaviour with a particular shapefile in QGIS
> 3.4.1. The data can be obtained here:
> https://drive.google.com/file/d/1BPVnsUbJREYh6TvLM07GAzXMiMneHemN/view?usp=sharing
> When I run the /Vector Geometry > Dissolve/ Processing tool on it, no
> errors are raised, an output layer is created containing one row with
> no geometry. This happens regardless of the Processing 'Invalid
> features filtering' setting.
> Running the /GDAL > Vector geoprocessing > Dissolve/ tool on the data
> immediately returns an invalid geometry (self intersection) error, but
> running /Vector Geometry > Check validity/ finds no errors using
> either the GEOS or QGIS engine.
> If the /Vector Geometry > Dissolve/ tool is run on a selection from
> the shapefile, it will complete successfully if all but one feature is
> selected, *regardless of which feature is left unselected*.
> I'm not sure whether this is a bug, or my data. Does anyone have any
> explanation for the observed behaviour?
> Cheers,
> Andy
> Andy Harfoot
> GeoData Institute
> University of Southampton
> Southampton
> SO17 1BJ
> Tel:  +44 (0)23 8059 2719
> www.geodata.soton.ac.uk
Andy Harfoot
GeoData Institute
Southampton
SO17 1BJ
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181119/517c0916/attachment.html>
