[Qgis-user] [QGIS-Developer] QGIS Processing "R" Provider -- 3.x beta available
Nyall Dawson nyall.dawson at gmail.com
Sun Nov 25 18:54:09 PST 2018
On Fri, 16 Nov 2018 at 20:29, Pedro VenĂ¢ncio <pedrongvenancio at gmail.com> wrote:
> I tried to install it on Windows 10, but I'm always getting this, when running the test script:
> This algorithm cannot be run :-(
> This algorithm requires R to be run. Unfortunately, it seems that R is not installed in your system, or it is not correctly configured to be used from QGIS
> Click here to know more about how to install and configure R to be used with QGIS
> I've R 3.5.1 (64bits) installed in my users folder (C:\Users\username\Documents\R\R-3.5.1), I put this path in R folder setting, without success. I've already tried to add the R path to environment variables, but again without success.
> R works well with RStudio in same machine.
> I'm with QGIS 3.4.1 from OSGeo4W 64bits.
> Do you have any hint?
Thanks for reporting this -- it's fixed in version 0.0.3. You can
fetch this here:
https://github.com/north-road/qgis-processing-r/releases/tag/0.0.3
Nyall
