[Qgis-user] HDF Bug [Was: Raster formats in Qgis 3.4]
Jorge Gustavo Rocha jgr at geomaster.pt
Wed Nov 28 13:41:19 PST 2018
Hi Alex,
Thanks for the example. I was able to read it without any problem (in
current QGIS master version).
I'm still using GDAL 2.2.3.
You can see the dialog at
https://gist.github.com/jgrocha/347e8fee0828d3c3176ed1644d76f897
I didn't trace the fix, but the problem is already solved (I think).
Regards,
Jorge Gustavo
Às 18:30 de 28/11/18, Alex M escreveu:
> On Qgis-user an issue was reported with loading HDF5 files in QGIS 3.4
> no Windows 10.
> I was able to confirm that HDF5 files fail in QGIS 3.4.1, on Linux also.
> Not just the user's file but file I also have. In both cases the files
> work fine in QGIS 2.18.
> This appears to be a regression related to subdatasets (sublayers). No
> dialog comes up asking the user which subdataset to load, and hence the
> load fails with a Provider is not Valid message.
> Only bug info I can find was an old patch that solved this 7 years ago:
> https://issues.qgis.org/issues/5041
> Here's a MODIS image in HDF5 for people to test with.
> https://drive.google.com/open?id=1hQEi3cRdVRlxih06nbo0gygAvJE08ft7
> A secondary, minor issue, the Browser doesn't see the file if it has an
> extension beyond .hdf, in this the case .h5 was what the user supplied.
> Thanks,
> Alex
> On 11/27/18 10:26, Alex M wrote:
>> Yes, please share with the group.
>> Thanks,
>> Alex
>> On 11/27/18 10:20, Anabel Lamaro wrote:
>>>  Thank you very much for your answer. I use Windows 10 and I have just
>>> installed version 3.14 Madeira of the Qgis software. I enclose the error
>>> message in a screenshot. I'll see if I can send you a link to the image.
>>> Thank you very much Anabel
>>> El mar., 27 nov. 2018 a las 14:33, Alex M (<tech_dev at wildintellect.com>)
>>> escribió:
>>>> Anabel,
>>>> QGIS 3 supports all the same formats, however the loading dialog did
>>>> change.
>>>> https://www.gdal.org/formats_list.html
>>>> Sometimes there can also be a slight variation in which drivers are
>>>> included in the gdal install, though that usually only applies to
>>>> proprietary formats like MrSID and ECW.
>>>> What operating system are you using, which version of QGIS 3.4.?, and
>>>> can you send a link with an example file others can test with?
>>>> Do you get an error message? Please explain more about how it's not
>>>> working.
>>>> Thanks,
>>>> Alex
>>>> On 11/27/18 09:17, Anabel Lamaro wrote:
>>>>> Good afternoon: I need to open some radar satellite images (Cosmo Skymed)
>>>>> that are in .h5 format (of the hdf type). With the previous version 2.18
>>>> it
>>>>> could open without inconvenience. I need help on this. Is there any
>>>> add-on
>>>>> to open this type of raster format? Thank you in advance! Anabel
>>>> http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail
>>>>> Libre
>>>>> de virus. www.avg.com
>>>>> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Logo*   Geomaster, LDA*
  *VENHA DESCOBRIR O CAMINHO DO OPEN SOURCE CONNOSC**O
Avenida Barros e Soares
N.º 423, 4715-214 Braga
VAT/NIF510 906 109
Phone  +351 253 680 323
Site       geomaster.pt <http://geomaster.pt>
GPS       41.53322, -8.41929
Jorge Gustavo Rocha
CTO
Mobile  +351 910 333 888
Email    jgr at geomaster.pt
