[Qgis-user] question about filtering
DelazJ
delazj at gmail.com
Wed Sep 12 06:18:05 PDT 2018
You can simply use a CASE WHEN expression in the field box. Not the same
example but see
https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/vector_properties.html#define-labels-based-on-expressions
Regards,
Harrissou
Le mer. 12 sept. 2018 à 15:00, Nicolas Cadieux <nicolas.cadieux at archeotec.ca>
a écrit :
> This should help.
> https://youtu.be/0y_Rh4tpYPM
> https://qgis.org/en/site/forusers/visualchangelog212/index.html?highlight=rule%20based%20labelling#feature-rule-based-labeling
> Please add the QGIS version and OS you are using if you need more
> information.
> Nicolas
> Le 12 sept. 2018 à 08:37, Boaz Bar Ilan <boazprosie at gmail.com> a écrit :
> hi
> I choose to show label on every polygon which describe, say , its area.
> how can I filter , or not to show , values that are out of selected range?
> what is the tool ?
> I didn't find any good explanation to rule base labeling in case this is
> the tool
> thanks
> boaz
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180912/ecb52ce8/attachment.html>
