[Qgis-user] Simple Vector-Editing Question - Deleting Multiple Rings at Once
Michael Treglia
mtreglia at gmail.com
Fri Sep 14 07:24:02 PDT 2018
Hi Delaz, Nicholas,
Thanks so much for the responses!
Delaz - your solution works - not sure if it's quicker/simpler to click on
the rings using the 'delete ring' tool, but it's a smart alternative option.
Nicholas - I think the challenge is that you can select the objects, but I
couldn't figure out a way to select rings for a bulk deletion, as it's more
about removing the holes (and selecting the bounding vertices) than
selecting the objects themselves. I'm happy to learn if I was just missing
something.
On a related note - for the Shape Digitizing toolbar, those tools only work
to create new polygons, not new parts of a multipolygon, correct? Or is
there a way to do that I've been missing? (I know you can merge tool in
this case as well, but figured I'd check).
Thanks!
Mike
On Wed, Sep 12, 2018 at 12:12 PM Nicolas Cadieux <
nicolas.cadieux at archeotec.ca> wrote:
> Hi,
> You have various selection tools in the GUI. (yellow box Icon with an
> arrow). If you use shift + left mouse click, you can add to the current
> selection. I think it is Ctlt + left mouse click in some version of QGIS.
> Nicolas
> On 2018-09-12 11:12 AM, Michael Treglia wrote:
> Hi All,
> I'm doing some work that entails fixing up some digitization based on
> per-pixel image classification. Sometimes there are polygons with lots of
> rings contained, so I'm using the Delete Ring tool, but that requires
> clicking on every individual ring. Is there a way to delete multiple rings
> at one time via clicking/dragging with a keyboard key held or anything like
> that?
> Thanks!
> Mike
> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180914/e220255a/attachment.html>
