[Qgis-user] Java and QGIS
Nicolas Boisteault
nicolas.boisteault at arb-na.fr
Mon Sep 24 07:55:14 PDT 2018
Yes it is confusing. Only Apache Tomcat depends on Java. When someone
speaks about Apache he is refering to Apache HTTP Server which doesn't
need Java to run.
Le 24/09/2018 à 16:48, Tyler Veinot a écrit :
> Ok, so since I am using QGIS, QGIS Server, and Lizmap setup via these
> directions
> https://opengislab.com/blog/2018/7/7/updated-installing-apache-qgis-server-and-lizmap-on-windows-os
> this setup is unaffected because it is running on Apache?
> But my setup using Tomcat with GeoServer is going to have issues in
> the future?
> I apologize for the confusion, I thought Apache and Apache Tomcat were
> flavors of the same thing; I thought they both depended on Java
> environments to run.
> Tyler
> On Mon, Sep 24, 2018 at 11:15 AM Régis Haubourg
> <regis.haubourg at gmail.com <mailto:regis.haubourg at gmail.com>> wrote:
> Hi,
> QGIS has nothing to do with Java. QGIS server can be run using
> Apache (not TOMCAT) or nginx and shouldn't be at all concerned.
> Regards,
> Régis
> Le lun. 24 sept. 2018 à 16:11, Tyler Veinot
> <tylerkveinot at gmail.com <mailto:tylerkveinot at gmail.com>> a écrit :
> Hi All;
> So my IT guy said that Java is being phased out and is no
> longer supported on many browsers and soon none. I have JRE
> and JDK setup as part of Apachie and Tomcat Services for
> running web maps using; Lizmap, GeoServer, QGIS/QGIS Server,
> and we have been looking at setting up a web map server using
> these technologies. Now I am wondering if I should look for
> another web server applet that does use Java or if it is a
> non-issue.
> I guess my question is with Java being phased out/not
> supported what do we turn to for a web server in the
> opensource GIS community?
> Thanks;
> Tyler
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180924/6acf40f4/attachment.html>
