[Qgis-user] problems MAC and ecw raster files
William Kyngesburye woklist at kyngchaos.com
Tue Apr 2 08:22:18 PDT 2019
That may be an option for now, but there is an issue with that option that needs to be addressed - the ECW DSDK has a very restrictive license, especially with US export.  Any distribution of any part of the DSDK must be able to enforce a restricted distribution (ie download).  That's why I package the GDAL format as a plugin and require the end user to download the ECW DSDK themselves - I don't have the means or interest in enforcing export restrictions.
The same applies to the MrSID DSDK and GDAL format.
> On Apr 2, 2019, at 4:49 AM, Saber Razmjooei <saber.razmjooei at lutraconsulting.co.uk> wrote:
> Alternatively, you can use this installer which has all the 3rd party GDAL plugins within the bundle:
> https://lutraconsulting.github.io/qgis-mac-packager/ <https://lutraconsulting.github.io/qgis-mac-packager/>
> Regards
> Saber
> On Mon, 1 Apr 2019 at 12:27, DelazJ <delazj at gmail.com <mailto:delazj at gmail.com>> wrote:
> Hi Azzura,
> It's not about GDAL itself but a plugin that is not embarked with GDAL and that you have to add: ECW plugin v2.4.0-1 <https://www.kyngchaos.com/files/software/frameworks/GDAL-ECW_Plugin-2.4.0-1.dmg> (or the 2.3 version depending on your GDAL version). You should find it under the GDAL Plugins section at https://www.kyngchaos.com/software/frameworks/
>  <https://www.kyngchaos.com/software/frameworks/>
> And you need to install the Intergraph sdk version mentioned next to the download link.
> Regards,
> Harrissou
> Le lun. 1 avr. 2019 à 11:59, Azzurra Lentini <lentini.azzurra at polymtl.ca <mailto:lentini.azzurra at polymtl.ca>> a écrit :
> Hi Mike thank you for the explaination.
> However I have tried from the website
> https://www.kyngchaos.com/software/frameworks/ <https://www.kyngchaos.com/software/frameworks/> to install
> GDAL Complete: GDAL 2.4 and 2.3 but it is still not working!!
> My qgis version is 2.18 and even if I did all GDAL COMPLETE
> installation, qgis is still giving me this message (when I try to add
> raster ecw:
> data source not supported !!
> Any other suggestion?
> should I install other software in my computer?
> Thank you, Azzurra
> Mike Hyslop <mdhyslop at mtu.edu <mailto:mdhyslop at mtu.edu>> a écrit :
> > Hi,
> > this process is outlined on the developer's web site:
> > Look for the section titled "GDAL Plugins" and find the corresponding
> > plugin for your version of GDAL.
> > Best,
> > Mike
> > On Thu, Mar 21, 2019 at 10:24 AM Antongeo76 <antoviscomi at gmail.com <mailto:antoviscomi at gmail.com>> wrote:
> >> Azzurra Lentini-2 wrote
> >> > Dear all in my Qgis 2.18 installed in my computer Mac I can not open
> >> > the raster file with extension .ecw
> >> > What can I do? is it normal?
> >> > In my pc windows I can open without any problem.
> >> > Thank you Azzurra.
> >> > _______________________________________________
> >> > Qgis-user mailing list
> >> > Qgis-user at .osgeo
> >> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> >> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> >> Hi Azzurra,
> >> for unix based sistems you need to local build ECW SDK to allow GDAL (QGIS)
> >> to read ECW raster
> >> Cheers
> >> Antonio
> >> Antonio
> >> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html <http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html>
> >> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>_______________________________________________
> Saber Razmjooei
> www.lutraconsulting.co.uk <http://www.lutraconsulting.co.uk/>
> +44 (0)7568 129733
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190402/f5867494/attachment-0001.html>
