[Qgis-user] union tool
DelazJ delazj at gmail.com
Thu Apr 4 20:49:26 PDT 2019
The merge algorithm
https://docs.qgis.org/3.4/en/docs/user_manual/processing_algs/qgis/vectorgeneral.html#merge-vector-layers
Harrissou
Le ven. 5 avr. 2019 à 07:45, Stefan Giese (WhereGroup) <
stefan.giese at wheregroup.com> a écrit :
> You can use virtual layers (one possibility) with a union statement,
> something like:
> SELECT geometry, field1, field2 FROM layer1
> UNION SELECT geometry, field1, field2 FROM layer2
> UNION SELECT geometry, field1, field2 FROM layer3
> Mit freundlichen Grüßen
> Stefan Giese
> Projektleiter/Consultant
> Aufwind durch Wissen!
> Qualifizierte Open-Source-Schulungen
> bei der www.foss-academy.com
> WhereGroup GmbH & Co. KG
> Schwimmbadstr. 2
> 79100 Freiburg
> Germany
> Fon: +49 (0)761 / 519 102 - 61
> Fax: +49 (0)761 / 519 102 - 11
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> Am 2019-04-05 05:45, schrieb Boaz Bar Ilan:
> > hi
> > is there a way to union many polygons which belongs to different
> > layers all at once?
> > thanks
> > boaz
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190405/9dd786a7/attachment.html>
