[Qgis-user] How to use spatial filtering in dataprovider filter
Luigi Pirelli
luipir at gmail.com
Wed Apr 10 12:26:25 PDT 2019
for not spatial enable layers (e.g. without embedded spatial operators)
AFAIK you should use create a qgis virtual layer or an external gdal vrt.
http://www.sigte.udg.edu/jornadassiglibre2016/wp-content/uploads/2016/01/qgis_vlayers.pdf
https://github.com/mhugo/qgis_vlayers/blob/master/README.md
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On Wed, 10 Apr 2019 at 11:01, Bo Victor Thomsen <bo.victor.thomsen at gmail.com>
wrote:
> Hi all -
> Im am experimenting with using the dataprovider based *spatial* filtering
> in QGIS
> For example: with a Postgres based datasource I can write a filter like
> this:
> ST_Intersects( "geometry", ST_GeomFromText(' Polygon ((582084. 6143051.
> ...... lots of coordinates ... 582084. 6143051.))', 25832))
> This will show a layer that only contains objects which actually
> intersects with the text defined polygon even if the unfiltered datasource
> contains a large number of objects taht does not intersect withe the text
> polygon
> Something similar can be done with SQLserver to: mygeom.ST_Intersects
> (...) = 1
> But what about ogr file based vector sources like tab or shape files ?
> You can define a *alfanumerical* filter like this : "myfield" > 27 to a
> ogr file datasource. Works like a charm.
> But what about *spatial filtering* ? Iv'e tried to use the same expression
> like the postgres one but on a shapefile. I don't get any errors :-).
> However the filter function doesn't work and let all objects through the
> filter :-(
> What am I doing wrong with the file based spatial filtering? Or is it
> simply impossible ?
> Med venlig hilsen
> Bo Victor Thomsen
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190410/5481d168/attachment.html>
