[Qgis-user] Processing: QGIS Crash with new processing script format, QGIS 3.6.1
Stefan Giese (WhereGroup) stefan.giese at wheregroup.com
Fri Apr 12 00:42:51 PDT 2019
Hi Havard,
thanks a lot, yes I will test it and send you my feedback within the
next days.
stefan
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei der www.foss-academy.com
WhereGroup GmbH & Co. KG
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 2019-04-12 08:50, schrieb Havard Tveite:
> Hi Stefan,
> We have recently updated the user manual to reflect this new
> great feature.
> Can you test the example that is given there (also includes
> two processing algorithms)?
> https://docs.qgis.org/testing/en/docs/user_manual/processing/scripts.html#the-alg-decorator
> Håvard
> On 12.04.2019 08:28, Stefan Giese wrote:
>> Hi everybody,
>> I've just played with the new (3.6.1) processing script format (see
>> https://github.com/qgis/QGIS-Enhancement-Proposals/issues/134 or
>> https://anitagraser.com/2019/03/02/easy-processing-scripts-comeback-in-qgis-3-6/)
>> and tried to put 2 processing algorithmen in it (centroid and buffer),
>> but without success. The script stopped with the ":( QGIS crashed" -
>> so anything goes wrong I suppose. May be someone can help me to get
>> the right idea to connect various processing steps within the new
>> format. my script is attached, it should take a polygon layer, make
>> the centroids and then buffer the points.
>> best regards
>> stefan
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
