[Qgis-user] Qgis 3.6 network analysis
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Mon Apr 15 21:13:44 PDT 2019
Hi again,
Thanks Nyall, Micha and Alessandro for your help on correcting the river
flow directions.  I am still working on it but you gave me the right
tools.  The next step of my project will be to use my river flow network
and find the shortest path between THOUSANDS of points (so I will need
to batch it or script it in Python).
It gets complicated as I will need to calculate the total trip for each
shortest path (easy) and then the percentage of that trip that was made
going downstream (the rest being the upstream trip).  I don't know if
there is a tool for that?  If not, my goal was to use the shortest path
lines to do a spatial query on my network and figure things from there.
Anyways, I don't have much experience with networks so that's what I
need to figure out.  I also mostly use Python outside of QGIS so my
questions are basic for now.  I see that many plugins have been
incorporated in Processing but the Shortest path (point to point) builds
a new graph every time.  I figure I need to build a graph but that does
not seem to be available in QGIS 3.6.
I found this
https://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/network_analysis.html#building-a-graph
but the very first command "from qgis.networkanalysis import *" in the
QGIS python console  indicates "ModuleNotFoundError: No module named
'qgis.networkanalysis'".
Question 1: Is the qgis.networkanalysis module being replaced or renamed
in QGIS 3.6 (OSGEO4w64 intall)?
Question 2: Since I will have THOUSANDS of shortest path lines to
calculate, is QGIS the best tool for the job?  Should I be looking at
NetworkX or iGraph? I played a bit with QNEAT3 but I don't know if I can
get it to create just a graph.  If you have any good examples of making
a graph from a shp file and then making a shortest path analysis, please
send it my way.
Question 3: What would be the best tool (or best practice) to check my
network integrity? v.clean?
Thanks again,
Nicolas
