[Qgis-user] GeoPackage-Hickups
Matthias Kuhn matthias at opengis.ch
Sat Apr 27 07:20:17 PDT 2019
Hi Bernd,
1. Only when you have set "automatically create transaction groups if
possible" in the project properties
2. Might possibly be resolved by #1 as well
Matthias
On 4/27/19 3:57 PM, Bernd Vogelgesang wrote:
> Hi,
> I try to use Geopackage as my standard format for a while, but so far my
> joy is only moderate.
> 1. Is it default behaviour, that when I make one layer of this
> GeoPackage editable, all other layers become editable as well?
> 2. Mostly I add or modify data in a non-spatial table with a relation to
> a point layer. "Most" of the time this works quite ok, but quite often
> the save of the changes is not possible, cause OGR claims that the
> database is locked. Toggle the edit status or refreshing the database in
> DB Manager does not help, so most of the time I have to shut down QGIS
> to be able to work on. Is there a "trick" to unlock the database without
> having to shut down the application? (btw. the files are stored on a
> synology network drive)
> QGIS 3.6.2 on Linux Mint
> Cheers,
> Bernd
> Qgis-user mailing list
Matthias Kuhn
matthias at opengis.ch <mailto:matthias at opengis.ch>
+41 (0)76 435 67 63 <tel:+41764356763>
OPENGIS.ch Logo <http://www.opengis.ch>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190427/94bd49fd/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190427/94bd49fd/attachment.png>
