[Qgis-user] finding the radius of a curve
Cory Albrecht maps at hanfastolfe.com
Mon Apr 29 09:21:32 PDT 2019
I tried saving a few layers that had arcs and circles (x,y, r coords), but
QGIS converts each curve to a bunch of straight line segments instead of
saving them as curves. :-(
On Mon, Apr 22, 2019 at 3:33 AM McDonaldR <McDonaldR at angus.gov.uk> wrote:
> As your data is in PostGIS and assuming that they are arcs (curved lines
> part of a circle) you could use some geometry and spatial SQL functions to
> calculate the radius of any curve knowing the coordinates of the end points
> of the curve.
> To quote the pseudo code on the linked page:
> “To calculate the radius of an arc, take the height -- "H" -- of the arc
> and divide it by two. Call the result "C." Now take the width -- "W" -- of
> the arc and square it by multiplying it by itself. Call the result "D."
> Next multiply height, "H," by eight and call this result "E." Divide "D" by
> "E" and call the result "F." The radius of the arc is C plus F.”
> https://sciencing.com/calculate-radius-curve-7804090.html
> Could probably be wrapped in a function and run against any curve.
> Ross
> *From:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *Cory Albrecht
> *Sent:* 19 April 2019 17:08
> *To:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] finding the radius of a curve
> I'll give it a try. Thanks!
> On Sun, Apr 14, 2019 at 7:52 AM Mike Flannigan <mikeflan at att.net> wrote:
> Draw a circle and measure the diameter/radius.
> Maybe use this plugin to create a circle:
> https://plugins.qgis.org/plugins/CADDigitize/
> Mike
> On 4/13/2019 2:00 PM, qgis-user-request at lists.osgeo.org wrote:
> > Hello all,
> > I'm looking for a way to find the radius of a curve (for roads,
> railyways)
> > in QGIS. If it were a paper map I could do it with a drafting compass
> > (calipers to some) and a ruler, but this is a PostGIS layer.
> > Any plugin recommendations or links to a set of steps to accomplish this?
> > Thanks in advance!
> This message is strictly confidential. If you have received this in error,
> please inform the sender and remove it from your system. If received in
> error you may not copy, print, forward or use it or any attachment in any
> way. This message is not capable of creating a legal contract or a binding
> representation and does not represent the views of Angus Council. Emails
> may be monitored for security and network management reasons. Messages
> containing inappropriate content may be intercepted. Angus Council does not
> accept any liability for any harm that may be caused to the recipient
> system or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190429/d911f1c6/attachment-0001.html>
