[Qgis-user] finding the radius of a curve
Andreas Neumann a.neumann at carto.net
Mon Apr 29 12:08:33 PDT 2019
Hi again,
On that matter: If you can isolate only the arc-part of your geometry,
you could that circular arc into the Postgis-function
"ST_MinimumBoundingRadius()" to detect center-point and radius. See
http://www.postgis.net/docs/manual-2.5/ST_MinimumBoundingRadius.html -
maybe worth a try?
Sample query:
SELECT ST_AsText(center), radius
    FROM ST_MinimumBoundingRadius('CIRCULARSTRING(220268 150415,220227
150505,220227 150406)');
RESULT:
"POINT(220237.62195122 150455.5)"    "50.6268293270462"
Greetings,
Andreas
Am 29.04.19 um 18:21 schrieb Cory Albrecht:
> I tried saving a few layers that had arcs and circles (x,y, r coords),
> but QGIS converts each curve to a bunch of straight line segments
> instead of saving them as curves. :-(
> On Mon, Apr 22, 2019 at 3:33 AM McDonaldR <McDonaldR at angus.gov.uk
> <mailto:McDonaldR at angus.gov.uk>> wrote:
>     As your data is in PostGIS and assuming that they are arcs (curved
>     lines part of a circle) you could use some geometry and spatial
>     SQL functions to calculate the radius of any curve knowing the
>     coordinates of the end points of the curve.
>     To quote the pseudo code on the linked page:
>     “To calculate the radius of an arc, take the height -- "H" -- of
>     the arc and divide it by two. Call the result "C." Now take the
>     width -- "W" -- of the arc and square it by multiplying it by
>     itself. Call the result "D." Next multiply height, "H," by eight
>     and call this result "E." Divide "D" by "E" and call the result
>     "F." The radius of the arc is C plus F.”
>     https://sciencing.com/calculate-radius-curve-7804090.html
>     Could probably be wrapped in a function and run against any curve.
>     Ross
>     *From:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org
>     <mailto:qgis-user-bounces at lists.osgeo.org>] *On Behalf Of *Cory
>     Albrecht
>     *Sent:* 19 April 2019 17:08
>     *To:* qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
>     *Subject:* Re: [Qgis-user] finding the radius of a curve
>     I'll give it a try. Thanks!
>     On Sun, Apr 14, 2019 at 7:52 AM Mike Flannigan <mikeflan at att.net
>     <mailto:mikeflan at att.net>> wrote:
>         Draw a circle and measure the diameter/radius.
>         Maybe use this plugin to create a circle:
>         https://plugins.qgis.org/plugins/CADDigitize/
>         Mike
>         On 4/13/2019 2:00 PM, qgis-user-request at lists.osgeo.org
>         <mailto:qgis-user-request at lists.osgeo.org> wrote:
>         > Hello all,
>         > I'm looking for a way to find the radius of a curve (for
>         roads, railyways)
>         > in QGIS. If it were a paper map I could do it with a
>         drafting compass
>         > (calipers to some) and a ruler, but this is a PostGIS layer.
>         > Any plugin recommendations or links to a set of steps to
>         accomplish this?
>         > Thanks in advance!
>     This message is strictly confidential. If you have received this
>     in error, please inform the sender and remove it from your system.
>     If received in error you may not copy, print, forward or use it or
>     any attachment in any way. This message is not capable of creating
>     a legal contract or a binding representation and does not
>     represent the views of Angus Council. Emails may be monitored for
>     security and network management reasons.Messages containing
>     inappropriate content may be intercepted. Angus Council does not
>     accept any liability for any harm that may be caused to the
>     recipient system or data on it by this message or any attachment.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190429/f8cb3685/attachment.html>
