[Qgis-user] Handle local layers in resources folder when project saved in PostgreSQL
Régis Haubourg regis.haubourg at gmail.com
Thu Dec 5 06:40:10 PST 2019
Hi Yann,
Sharing reference datasets as files in /usr does not sound like a good idea
when you already have a database. I strongly recommend using the database
for this, except for rasters.   And yes, offline editing works with
database, except fpr rasters :)
Regards
Régis
Le jeu. 5 déc. 2019 à 13:43, Yann Voté <ygversil at lilo.org> a écrit :
> Thank you all for your answers.
> Alessandro: the resources folder contains only read-only data (reference
> rasters or vectors from French national geographic institute, not to be
> modified). I deploy these layers on every workstation. Is it still a bad
> practice for read-only reference data to use this folder ?
> Raymond: indeed I'm currently working on a plugin, and I've seen
> QgsPathResolver. But documentation for this class is quite terse. but
> I'll continue to investigate and experiment.
> Jorge: interesting setup. Does the offline editing plugin work when
> everything is in database ? In other words, are raster layers converted
> offline ?
> Cheers.
> Yann
> Le 05/12/2019 à 13:16, Jorge Gustavo Rocha a écrit :
> > Hi,
> > In my setup - using PGSERVICES - all vector, raster, styles and projects
> > are stored on database. This is my preferred way to organize the data:
> > on a database. QGIS Server also takes advantage of this setup and
> > publish the projects directly from the database, using the rasters (in
> > db or out of db rasters).
> > The few things I'm not sharing on the database are SVG, layout images
> > and fonts.
> > There are problems with Postgresql/GDAL access to Postgresql, but if
> > using PGSERVICES it works.
> > Best regards,
> > Jorge
> > On 05/12/19 11:18, Alessandro Pasotti wrote:
> >> On Thu, Dec 5, 2019 at 11:58 AM Yann Voté <ygversil at lilo.org
> >> <mailto:ygversil at lilo.org>> wrote:
> >>     Hi all,
> >>     I can't find a solution to the following issue, or a way to work
> >>     around
> >>     it: I have created a project with some PostgreSQL layers to edit and
> >>     some raster layers on local filesystem. I work on a Linux computer
> >>     and
> >>     have put the local layers into the pkg data path resources folder
> >>     (/usr/share/qgis/resources/local/raster.gpkg).
> >> Sorry but this is not a good idea, that path is usually not
> >> user-writeable and should not be used to store any user related
> >> information.
> >> But if I understand correctly what you were trying to do I'm afraid
> >> there is not a solution: the concept of "relative path" means relative
> >> to the project's storage path but that path does not make any sense in
> >> case of a POSTGRES storage (because POSTGRES is not a local
> >> filesystem-based DB in the same sense as GPKG or SPATIALITE are), so
> >> your file-system based asset paths are not (and cannot be) converted
> >> to relative paths because there is no project path we can relate to.
> >> This makes portability an issue if the project has filesystem-based
> >> layers (rasters in your case).
> >> There is no solution I'm aware of, storing rasters into PG is also not
> >> a viable option at the moment because support is currently buggy (see:
> >> https://github.com/qgis/QGIS/issues/30392).
> >> Cheers
> >>     I have also saved the project into PostgreSQL so that it can be
> >>     shared
> >>     easily. Other users work on Windows computers and have the same
> >>     rasters
> >>     under pkg data path resources folder
> >>     (C:/PROGRAM~1/QGIS3~1.8/apps/qgis/resources/local/raster.gpkg).
> >>     But when
> >>     they open the project, Postgis layers are loaded fine, but QGIS says
> >>     that raster.gpkg cannot be found under the /usr/share/... path.
> >>     I would expect that layers in the pkg data path resources folder are
> >>     saved with the inbuilt: prefix, but in fact they are not.
> >>     Moreover, it
> >>     seems that one cannot select "Relative" for saving layer paths, in
> >>     project properties, when project is saved to PostgreSQL. Looks
> >>     sensible
> >>     (what is the relative path to a PostgreSQL table ?), but then what
> >>     can I
> >>     do to share a PostgreSQL project with local layers ?
> >>     We all use QGIS 3.8.3.
> >>     Thank you for any advice !
> >>     Cheers
> >>     Yann
> >>     _______________________________________________
> >>     Qgis-user mailing list
> >>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> >>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Alessandro Pasotti
> >> w3: www.itopen.it <http://www.itopen.it>
> >> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Email Signature
> > Logo <https://www.geomaster.pt>
> > *Geomaster*
> > *Jorge Gustavo Rocha* | Software Engineer
> > *e:*jgr at geomaster.pt | *m:*+351 910 333 888
> > *g:*41.54094,-8.40490 | *v: *510 906 109
> > *a: * Rua António Cândido Pinto, 67, 4715-400 Braga
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191205/77072e01/attachment-0001.html>
