[Qgis-user] Data defined assistant apparently does not work with buffer tool
Hernán De Angelis
dhdeangelis at comhem.se
Fri Dec 6 00:18:21 PST 2019
This is the report I mentioned:
https://github.com/qgis/QGIS/issues/29433
It is not exactly the same issue, but a report on the editor and the
assistant not working together properly. Of course this is not to say
that these have the same cause.
Nyall, could you reproduce the problem I wrote about?
/H.
On 2019-12-06 00:22, Nyall Dawson wrote:
> On Wed, 4 Dec 2019 at 21:39, Hernán De Angelis <dhdeangelis at comhem.se> wrote:
>> Hi QGIS'ers
>> I am experiencing a problem while trying to generate vector buffers using functions or fields using the "assistant".
>> The buffer tool works as expected for fixed buffer widths and when using the expression editor but seemingly does not work (or produces weird scaling problems) for data defined buffers if I use the "assistant".
>> I see in GitHub this has been reported for the symbology editor but it seems that it also affects the buffer tool. I am using QGIS 3.10.0.
> Which bug report is this?
> Nyall
>> Has anyone also experienced this?
>> Hernán
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
