[Qgis-user] problems running saga tools in QGIS 3.4.13
Jonathan Aguero Valverde jaguero.ucr at gmail.com
Mon Dec 9 06:10:23 PST 2019
Dear Nicolas,
You were exactly right, the problem was the spaces and accent in the
path. I did ran the interpolation in SAGA but the it was just a part of
the whole process which is much more easier to run completely inside qgis.
Regards
Jonathan.
El 7/12/2019 a las 21:30, Nicolas Cadieux escribió:
> Hi,
> The easiest way is just to use Saga directly. Possible problem is that
> you have a space and accent in the path. « San Ramón ».  You could try
> removing those.
> Nicolas
>> Le 7 déc. 2019 à 17:01, Jonathan Aguero <jaguero.ucr at gmail.com> a écrit :
>> Hi list,
>> I am trying to run the IDW interpolation using the SAGA tool inside
>> QGIS. I installed the pre-packaged version for win10 with qgis 3.4.13
>> and SAGA 2.3.2. I got the following messages:
>> Loading resulting layers
>> The following layers were not correctly
>> generated.<ul><li>C:/Users/Jonathan/AppData/Local/Temp/processing_99d6ec7b49d940d5981d865b31db13c7/aa2d1cef96c54efe8fc9201957fa5d8b/TARGET_OUT_GRID.sdat</li></ul>Youcan
>> check the 'Log Messages Panel' in QGIS main window to find more
>> information about the execution of the algorithm.
>>  C:\Users\Jonathan\Documents>call saga_cmd grid_gridding "Inverse
>> Distance Weighted" -SHAPES "C:/Users/Jonathan/Documents/San
>> Ramón/centroides1.shp" -FIELD "_range" -DW_WEIGHTING 1 -DW_IDW_POWER
>> 2.0 -DW_IDW_OFFSET false -DW_BANDWIDTH 1.0 -SEARCH_RANGE 0
>> -SEARCH_RADIUS 1000.0 -SEARCH_POINTS_ALL 0 -SEARCH_POINTS_MIN -1
>> -SEARCH_POINTS_MAX 20 -SEARCH_DIRECTION 0 -TARGET_USER_SIZE 25.0
>> -TARGET_DEFINITION 0 -TARGET_USER_FITS 0 -TARGET_OUT_GRID
>> "C:/Users/Jonathan/AppData/Local/Temp/processing_99d6ec7b49d940d5981d865b31db13c7/aa2d1cef96c54efe8fc9201957fa5d8b/TARGET_OUT_GRID.sdat"
>> Can someone help me find out the problem here?
>> Regards
>> Jo
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Ing. Jonathan Agüero Valverde, Ph.D.
Profesor e Investigador
Programa de Investigación en Desarrollo Urbano Sostenible  (ProDUS)
Escuela de Ingeniería Civil
Universidad de Costa Rica
Tel: (506) 2511-2787, 2511-2777
jonathan.aguero at ucr.ac.cr
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191209/b663fafc/attachment.html>
