[Qgis-user] QGIS Server / GetPrint not rendering all the layers (XYZ Tiles for example)
Etienne Trimaille etienne.trimaille at gmail.com
Thu Dec 12 23:36:59 PST 2019
Hi Arnaud,
It looks like a cache write issue.
QGIS_OPTIONS_PATH must be a directory, not a file path.
https://docs.qgis.org/testing/en/docs/user_manual/working_with_ogc/server/config.html#qgis-options-path
I would add QGIS_OPTIONS_PATH too. And check that the profile is writable
for QGIS Server (www-data?). After the GetPrint request, I think you should
see the cache folder created.
This my config :
QGIS_CUSTOM_CONFIG_PATH=/home/etienne/dev/qgis/server_home/profile
QGIS_OPTIONS_PATH=/home/etienne/dev/qgis/server_home
QGIS_PLUGINPATH=/home/etienne/dev/qgis/server_plugin
Can you check that?
Le ven. 13 déc. 2019 à 07:25, Arnaud Vandecasteele <arnaud.sig at gmail.com> a
écrit :
> Distribution Ubuntu
> QGIS Server on server -> Version: 3.4.11+dfsg-2~bionic1
> QGIS Server on computer -> Version: 3.4.13+dfsg-3~bionic2
> I have QGIS Server installed on my computer and on my server. The same
> project is used on both. This project is very simple and contains a SHP
> layer and a XYZ OpenStreetMap layer. When printing the map (GetPrint) on my
> computer all layers are correctly displayed.
> The same operation on the server displays only the SHP layer and not the
> XYZ layer.
> When the GetPrint request is made on the server, the following lines are
> added to the log file:
> ERROR: Opening of authentication db FAILED
> QSqlQuery::prepare: database not open
> WARNING: Auth db query exec() FAILED
> However, I have the impression that my configuration file is correctly
> configured:
>         FcgidInitialEnv DISPLAY":99"
>         FcgidInitialEnv QGIS_SERVER_LOG_LEVEL "0"
>         FcgidInitialEnv QGIS_SERVER_LOG_STDERR "1"
>         FcgidInitialEnv QGIS_AUTH_DB_DIR_PATH "/home/qgis/qgisserverdb"
>         FcgidInitialEnv QGIS_AUTH_PASSWORD_FILE
> "/home/qgis/qgisserverdb/qgis-auth.db"
>         FcgidInitialEnv QGIS_PREFIX_PATH /usr
>         FcgidInitialEnv QGIS_OPTIONS_PATH
> /data/owncloud-data/arnaud/files/GEOLAB/Transfert/webmapping-lizmap/QGIS3.ini
>         <Rental /qgisserver>
>                 SetHandler fcgid-script
>                 FcgidWrapper /usr/lib/cgi-bin/qgis_mapserv.fcgi virtual
>                 Options +ExecCGI -MultiViews +FollowSymLinks
>                 Require all granted
>         </Location>
>         ErrorLog ${APACHE_LOG_DIR}/map-error.log
>         LogLevel warn
>         CustomLog ${APACHE_LOG_DIR}/map-access.log combined
> And the permissions look good:
> ls -l /home/qgis/
> drwxr-xr-x 2 www-data www-data www-data 4096 Oct 25 08:46 cache
> drwxr-xr-xx 2 www-data www-data www-data 4096 Jun 20 07:32 qgisserverdb
> Do you have any idea what might cause this problem?
> Thank you in advance,
> Arnaud
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191213/79de864d/attachment.html>
