[Qgis-user] QGIS Server / GetPrint not rendering all the layers (XYZ Tiles for example)
Arnaud Vandecasteele arnaud.sig at gmail.com
Fri Dec 13 02:05:16 PST 2019
Hi All,
I've changed the configuration fro :
FcgidInitialEnv QGIS_AUTH_DB_DIR_PATH "/tmp/qgisserver"
FcgidInitialEnv QGIS_AUTH_PASSWORD_FILE "/tmp/qgisserver/qgis-auth.db"
The qgisserver Folder inside tmp belongs to www-data and for tje test I set
the permission to 777 :
ls -l /tmp/
drwxrwxrwx 2 www-data www-data 4096 Dec 13 11:01 qgisserver
Event with that no qgis-auth.db has been created and still the same error
ERROR: Auth db directory path could not be created
Initializing server modules from  "/usr/lib/qgis/server"
"Checking /usr/lib/qgis/server for native services modules"
"Loading native module /usr/lib/qgis/server/libdummy.so"
"Loading native module /usr/lib/qgis/server/libwcs.so"
"Loading native module /usr/lib/qgis/server/libwfs.so"
"Loading native module /usr/lib/qgis/server/libwms.so"
"Loading native module /usr/lib/qgis/server/libwmts.so"
ERROR: Opening of authentication db FAILED
QSqlQuery::prepare: database not open
WARNING: Auth db query exec() FAILED
Arnaud
On Fri, Dec 13, 2019 at 1:06 PM Werner Macho <werner.macho at gmail.com> wrote:
> Hi,
> To me it looks like the server cannot create the path to store its
> credentials:
> Could you probably check permissions if the server is allowed to write
> there?
> regards
> Werner
> On Fri, Dec 13, 2019 at 10:03 AM Arnaud Vandecasteele <
> arnaud.sig at gmail.com> wrote:
>> Hi Alessandro,
>> Indeed there is no db file created.
>> I've checked the link you gave me, but I don't know what to with this. Am
>> I suppose to execute something ?
>> Best,
>> Arnaud
>> Le ven. 13 déc. 2019 à 12:50, Alessandro Pasotti <apasotti at gmail.com> a
>> écrit :
>>> On Fri, Dec 13, 2019 at 9:17 AM Arnaud Vandecasteele <
>>>> Hi Etienne,
>>>> Thanks for your help.
>>>> As suggested, I change the config for :
>>>>         FcgidInitialEnv DISPLAY ":99"
>>>>         FcgidInitialEnv QGIS_SERVER_LOG_LEVEL "0"
>>>>         FcgidInitialEnv QGIS_SERVER_LOG_STDERR "1"
>>>> "/home/arnaudvandecasteele/qgisserver"
>>>> "/home/arnaudvandecasteele/qgisserver/qgis-auth.db"
>>>>         FcgidInitialEnv QGIS_PREFIX_PATH /usr
>>>>         FcgidInitialEnv QGIS_OPTIONS_PATH
>>>> The folder rights looks ok.
>>>> ls -l
>>>> drwxrwxr-x 2 www-data            www-data                  4096 Dec 13
>>>> 08:45 qgisserver
>>>> Unfortunately the error remain :
>>>> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP
>>>> environment variable.
>>>> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
>>>> As I understand the use of the authentification system in desktop mode,
>>>> it is still a bit confusing for me when using a server.
>>>> For example, I don't have any qgis-auth.db file on my server. Do I have
>>>> to copy it from my desktop ?
>>> Hi,
>>> no, you don't need to copy it unless you want to use the credentials
>>> you've stored in it.
>>> The DB will be created automatically if it doesn't exist when QGIS
>>> Server process starts.
>>> See:
>>> https://github.com/qgis/QGIS/blob/master/src/server/qgsserver.cpp#L245
>>>> Thanks again,
>>>> Best,
>>>> Arnaud
>>>> On Fri, Dec 13, 2019 at 11:37 AM Etienne Trimaille <
>>>> etienne.trimaille at gmail.com> wrote:
>>>>> Hi Arnaud,
>>>>> It looks like a cache write issue.
>>>>> QGIS_OPTIONS_PATH must be a directory, not a file path.
>>>>> https://docs.qgis.org/testing/en/docs/user_manual/working_with_ogc/server/config.html#qgis-options-path
>>>>> I would add QGIS_OPTIONS_PATH too. And check that the profile is
>>>>> writable for QGIS Server (www-data?). After the GetPrint request, I think
>>>>> you should see the cache folder created.
>>>>> This my config :
>>>>> QGIS_CUSTOM_CONFIG_PATH=/home/etienne/dev/qgis/server_home/profile
>>>>> QGIS_OPTIONS_PATH=/home/etienne/dev/qgis/server_home
>>>>> QGIS_PLUGINPATH=/home/etienne/dev/qgis/server_plugin
>>>>> Can you check that?
>>>>> Le ven. 13 déc. 2019 à 07:25, Arnaud Vandecasteele <
>>>>> arnaud.sig at gmail.com> a écrit :
>>>>>> Distribution Ubuntu
>>>>>> QGIS Server on server -> Version: 3.4.11+dfsg-2~bionic1
>>>>>> QGIS Server on computer -> Version: 3.4.13+dfsg-3~bionic2
>>>>>> I have QGIS Server installed on my computer and on my server. The
>>>>>> same project is used on both. This project is very simple and contains a
>>>>>> SHP layer and a XYZ OpenStreetMap layer. When printing the map (GetPrint)
>>>>>> on my computer all layers are correctly displayed.
>>>>>> The same operation on the server displays only the SHP layer and not
>>>>>> the XYZ layer.
>>>>>> When the GetPrint request is made on the server, the following lines
>>>>>> are added to the log file:
>>>>>> However, I have the impression that my configuration file is
>>>>>> correctly configured:
>>>>>>         FcgidInitialEnv DISPLAY":99"
>>>>>> "/home/qgis/qgisserverdb"
>>>>>> "/home/qgis/qgisserverdb/qgis-auth.db"
>>>>>> /data/owncloud-data/arnaud/files/GEOLAB/Transfert/webmapping-lizmap/QGIS3.ini
>>>>>>         <Rental /qgisserver>
>>>>>>                 SetHandler fcgid-script
>>>>>>                 FcgidWrapper /usr/lib/cgi-bin/qgis_mapserv.fcgi
>>>>>> virtual
>>>>>>                 Options +ExecCGI -MultiViews +FollowSymLinks
>>>>>>                 Require all granted
>>>>>>         </Location>
>>>>>>         ErrorLog ${APACHE_LOG_DIR}/map-error.log
>>>>>>         LogLevel warn
>>>>>>         CustomLog ${APACHE_LOG_DIR}/map-access.log combined
>>>>>> And the permissions look good:
>>>>>> ls -l /home/qgis/
>>>>>> drwxr-xr-x 2 www-data www-data www-data 4096 Oct 25 08:46 cache
>>>>>> drwxr-xr-xx 2 www-data www-data www-data 4096 Jun 20 07:32
>>>>>> qgisserverdb
>>>>>> Do you have any idea what might cause this problem?
>>>>>> Thank you in advance,
>>>>>> Arnaud
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> SIG - WebMapping - Spatial Ontology - GeoCollaboration
>>>> Web Site
>>>> http://geotribu.net/
>>>> http://about.me/arnaud_vandecasteele
>>> Alessandro Pasotti
>>> w3:   www.itopen.it
Web Site
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191213/cb7db3f7/attachment-0001.html>
