[Qgis-user] Qgis-user Digest, Vol 166, Issue 14
Arnaud Vandecasteele arnaud.sig at gmail.com
Fri Dec 13 02:59:21 PST 2019
I've finally found the problem.
My qgis server works configuration is defined inside a virtual host :
<VirtualHost *:80>
        ServerAdmin ***
        ServerName ***
        ServerAlias ***
        DocumentRoot***
        FcgidInitialEnv DISPLAY ":99"
        FcgidInitialEnv QGIS_SERVER_LOG_LEVEL "0"
        FcgidInitialEnv QGIS_SERVER_LOG_STDERR "1"
        FcgidInitialEnv QGIS_AUTH_DB_DIR_PATH "/home/qgis/qgisserverdb/"
        FcgidInitialEnv QGIS_AUTH_PASSWORD_FILE
"/home/qgis/qgisserverdb/qgis-auth.db"
        FcgidInitialEnv QGIS_PREFIX_PATH /usradd
        FcgidInitialEnv QGIS_OPTIONS_PATH "/home/qgis/qgisserver/"
        <Location /qgisserver>
                SetHandler fcgid-script
                FcgidWrapper /usr/lib/cgi-bin/qgis_mapserv.fcgi virtual
                Options +ExecCGI -MultiViews +FollowSymLinks
                Require all granted
        </Location>
        ErrorLog ${APACHE_LOG_DIR}/map-error.log
        LogLevel warn
        CustomLog ${APACHE_LOG_DIR}/map-access.log combined
</VirtualHost>
Now if I add the parameters QGIS_AUTH_DB_DIR_PATH and
QGIS_AUTH_PASSWORD_FILE in 000-default.conf (instead of the specific map
virtual host) the XYZ tiles are loaded and the qgis-auth.db files is
created.
I would prefer to keep all the parameters inside the same virtual host
config file but at least I've a working solution.
Thanks all of you for help !
Best,
Arnaud
On Fri, Dec 13, 2019 at 12:51 PM <qgis-user-request at lists.osgeo.org> wrote:
> Send Qgis-user mailing list submissions to
>         qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>    1. Re: Working with DEMs (Dave Gardiner)
>    2. Re: Working with DEMs (Bernd Vogelgesang)
>    3. Re: QGIS Server / GetPrint not rendering all the layers (XYZ
>       Tiles for example) (Etienne Trimaille)
>    4. Re: Working with DEMs (Dave Gardiner)
>    5. Re: Working with DEMs (Bernd Vogelgesang)
>    6. Re: QGIS Server / GetPrint not rendering all the layers (XYZ
>       Tiles for example) (Arnaud Vandecasteele)
>    7. Re: QGIS Server / GetPrint not rendering all the layers (XYZ
>       Tiles for example) (Alessandro Pasotti)
> Message: 1
> Date: Thu, 12 Dec 2019 23:55:15 -0700 (MST)
> From: Dave Gardiner <2dave.gardiner at gmail.com>
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Working with DEMs
> Message-ID: <1576220115629-0.post at n6.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> Hi Harvard
> I have extracted the nodes from the contour lines with the elevation field
> extracted. Could you please explain further how I generate a raster using a
> tin or spline interpolation. Where are these commands (Version 3.4.13).
> Kind Regards
> Dave
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Message: 2
> Date: Fri, 13 Dec 2019 08:05:58 +0100
> From: Bernd Vogelgesang <bernd.vogelgesang at gmx.de>
> Message-ID: <94cc9324-c6a0-d5d5-9b42-74ae35192048 at gmx.de>
> Content-Type: text/plain; charset=utf-8; format=flowed
> just type "interpolation" into the search field of the tool box, and all
> the functions will jump right into your face.
> Am 13.12.19 um 07:55 schrieb Dave Gardiner:
> > Hi Harvard
> field
> using a
> > Kind Regards
> > Dave
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Message: 3
> Date: Fri, 13 Dec 2019 08:36:59 +0100
> From: Etienne Trimaille <etienne.trimaille at gmail.com>
> To: Arnaud Vandecasteele <arnaud.sig at gmail.com>
> Cc: qgis-user <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] QGIS Server / GetPrint not rendering all the
>         layers (XYZ Tiles for example)
> Message-ID:
>         <CAMtDFLL=n7x_O=gQbxHYrVopfE2WQdYgOiOy9tOt+qHYg4=
> J-g at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hi Arnaud,
> It looks like a cache write issue.
> QGIS_OPTIONS_PATH must be a directory, not a file path.
> https://docs.qgis.org/testing/en/docs/user_manual/working_with_ogc/server/config.html#qgis-options-path
> I would add QGIS_OPTIONS_PATH too. And check that the profile is writable
> for QGIS Server (www-data?). After the GetPrint request, I think you should
> see the cache folder created.
> This my config :
> QGIS_CUSTOM_CONFIG_PATH=/home/etienne/dev/qgis/server_home/profile
> QGIS_OPTIONS_PATH=/home/etienne/dev/qgis/server_home
> QGIS_PLUGINPATH=/home/etienne/dev/qgis/server_plugin
> Can you check that?
> Le ven. 13 déc. 2019 à 07:25, Arnaud Vandecasteele <arnaud.sig at gmail.com>
> a
> écrit :
> > Distribution Ubuntu
> > QGIS Server on server -> Version: 3.4.11+dfsg-2~bionic1
> > QGIS Server on computer -> Version: 3.4.13+dfsg-3~bionic2
> > I have QGIS Server installed on my computer and on my server. The same
> > project is used on both. This project is very simple and contains a SHP
> > layer and a XYZ OpenStreetMap layer. When printing the map (GetPrint) on
> my
> > computer all layers are correctly displayed.
> > The same operation on the server displays only the SHP layer and not the
> > XYZ layer.
> > When the GetPrint request is made on the server, the following lines are
> > added to the log file:
> > ERROR: Opening of authentication db FAILED
> > QSqlQuery::prepare: database not open
> > WARNING: Auth db query exec() FAILED
> > However, I have the impression that my configuration file is correctly
> > configured:
> >         FcgidInitialEnv DISPLAY":99"
> >         FcgidInitialEnv QGIS_AUTH_DB_DIR_PATH "/home/qgis/qgisserverdb"
> /data/owncloud-data/arnaud/files/GEOLAB/Transfert/webmapping-lizmap/QGIS3.ini
> >         <Rental /qgisserver>
> >                 Require all granted
> >         </Location>
> >         LogLevel warn
> > And the permissions look good:
> > ls -l /home/qgis/
> > drwxr-xr-x 2 www-data www-data www-data 4096 Oct 25 08:46 cache
> > drwxr-xr-xx 2 www-data www-data www-data 4096 Jun 20 07:32 qgisserverdb
> > Do you have any idea what might cause this problem?
> > Thank you in advance,
> > Arnaud
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20191213/79de864d/attachment-0001.html
> Message: 4
> Date: Fri, 13 Dec 2019 00:50:23 -0700 (MST)
> Message-ID: <1576223423876-0.post at n6.nabble.com>
> I see them all and every one I use fails. Take the TIN Interpolation for
> example for which my input was:
> Vector Layer = Vertices (this is the layer with the extracted vector
> endpoint nodes on)
> Interpolation Attribute = Elevation
> Use Z point for Interpolation - ticked
> Input Layer = (Vector Layer = Vertices, Attribute=ZCOORD, type=POINT)
> Interpolation Method=Linear
> Extent=Canvas Extend
> This is my error.
> Traceback (most recent call last):
> File
> "C:/PROGRA~2/QGIS3~1.4/apps/qgis-ltr/./python/plugins\processing\algs\qgis\TinInterpolation.py",
> line 187, in processAlgorithm
> writer.writeFile(feedback)
> Exception: unknown
> Execution failed after 16.94 seconds
> Any thoughts please?
> Dave
> Message: 5
> Date: Fri, 13 Dec 2019 09:16:10 +0100
> Message-ID: <17da1ed3-a3dd-1715-8046-23f137500569 at gmx.de>
> mhm, not a single one works?  can you send me a sample of your points?
> Am 13.12.19 um 08:50 schrieb Dave Gardiner:
> > endpoint nodes on)
> > This is my error.
> > File
> > Exception: unknown
> > Dave
> Message: 6
> Date: Fri, 13 Dec 2019 12:17:11 +0400
> From: Arnaud Vandecasteele <arnaud.sig at gmail.com>
> To: Etienne Trimaille <etienne.trimaille at gmail.com>
> Message-ID:
> CAHZ2jmAcCSOxeVqA11OyqPPv2U6u2DQ_6z2NJbDxKOqy99DnvA at mail.gmail.com>
> Hi Etienne,
> Thanks for your help.
> As suggested, I change the config for :
> "/home/arnaudvandecasteele/qgisserver"
> "/home/arnaudvandecasteele/qgisserver/qgis-auth.db"
> The folder rights looks ok.
> ls -l
> drwxrwxr-x 2 www-data            www-data                  4096 Dec 13
> 08:45 qgisserver
> Unfortunately the error remain :
> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP environment
> variable.
> variable.
> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
> environment variable.
> variable.
> ERROR: Auth db directory path could not be created
> Initializing server modules from  "/usr/lib/qgis/server"
> "Checking /usr/lib/qgis/server for native services modules"
> "Loading native module /usr/lib/qgis/server/libdummy.so"
> "Loading native module /usr/lib/qgis/server/libwcs.so"
> "Loading native module /usr/lib/qgis/server/libwfs.so"
> "Loading native module /usr/lib/qgis/server/libwms.so"
> "Loading native module /usr/lib/qgis/server/libwmts.so"
> As I understand the use of the authentification system in desktop mode, it
> is still a bit confusing for me when using a server.
> For example, I don't have any qgis-auth.db file on my server. Do I have to
> copy it from my desktop ?
> Thanks again,
> Best,
> Arnaud
> On Fri, Dec 13, 2019 at 11:37 AM Etienne Trimaille <
> etienne.trimaille at gmail.com> wrote:
> > Hi Arnaud,
> should
> > This my config :
> > Can you check that?
> > a écrit :
> >> Distribution Ubuntu
> on my
> >> XYZ layer.
> >> configured:
> >>                 Require all granted
> >>         </Location>
> >>         LogLevel warn
> >> ls -l /home/qgis/
> >> Arnaud
> SIG - WebMapping - Spatial Ontology - GeoCollaboration
> Web Site
> http://geotribu.net/
> http://about.me/arnaud_vandecasteele
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20191213/d8b194e9/attachment-0001.html
> Message: 7
> Date: Fri, 13 Dec 2019 09:50:20 +0100
> From: Alessandro Pasotti <apasotti at gmail.com>
> Cc: Etienne Trimaille <etienne.trimaille at gmail.com>, qgis-user
> Message-ID:
> CAL5Q671A-dO9HGnA8N3YYmVaBaW4O65PfLop0Fe-3QJ4f4+esA at mail.gmail.com>
> On Fri, Dec 13, 2019 at 9:17 AM Arnaud Vandecasteele <arnaud.sig at gmail.com
> wrote:
> > Hi Etienne,
> > ls -l
> > 08:45 qgisserver
> > variable.
> > variable.
> > variable.
> it
> to
> Hi,
> no, you don't need to copy it unless you want to use the credentials you've
> stored in it.
> The DB will be created automatically if it doesn't exist when QGIS Server
> process starts.
> See:
> https://github.com/qgis/QGIS/blob/master/src/server/qgsserver.cpp#L245
> > Thanks again,
> > Best,
> > Arnaud
> >> Hi Arnaud,
> writable
> should
> >> This my config :
> >> Can you check that?
> >> a écrit :
> >>> Distribution Ubuntu
> on my
> the
> >>> XYZ layer.
> are
> >>> configured:
> >>>                 Require all granted
> >>>         </Location>
> >>>         LogLevel warn
> >>> ls -l /home/qgis/
> >>> Arnaud
> > Web Site
> Alessandro Pasotti
> w3:   www.itopen.it
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20191213/4c55d3d7/attachment.html
> Subject: Digest Footer
> End of Qgis-user Digest, Vol 166, Issue 14
Web Site
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191213/f5fce562/attachment-0001.html>
