[Qgis-user] Editing Oracle table - can't add feature
p.jeremie p.jeremie at gmail.com
Fri Dec 13 06:09:15 PST 2019
Hello,
I found that if the table contains geometry in 3D with SRID 2154, QGIS can't
add the geometry in the table.
If the geometry is 2D, it's ok.
Still, I don't understand why I don't have the PRIMARY KEY column not filled
whereas it is defined in the database...
And why QGIS tells me that the SRID is not defined whereas it is defined in
the MDSYS.USER_SDO_GEOM_METADATA view.
Any idea ?
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
