[Qgis-user] Working with DEMs
Håvard Tveite havard.tveite at nmbu.no
Mon Dec 16 15:05:18 PST 2019
Hi Dave,
When "Use Z-coordinate for interpolation" is checked, it must be
assumed that the Z coordinate will be used *instead* of the
value in the "Elevation" attribute.
But it is strange that this should cause the Exception / error
you experience.
The TIN Interpolator seems to works fine here (QGIS 3.4.14 on
Ubuntu 18.04) when using an attribute for the elevation.
I have not tested with Z-values.
Håvard
On 13.12.19 08:50 Dave Gardiner wrote:
> I see them all and every one I use fails. Take the TIN Interpolation for
> example for which my input was:
> Vector Layer = Vertices (this is the layer with the extracted vector
> endpoint nodes on)
> Interpolation Attribute = Elevation
> Use Z point for Interpolation - ticked
> Input Layer = (Vector Layer = Vertices, Attribute=ZCOORD, type=POINT)
> Interpolation Method=Linear
> Extent=Canvas Extend
> This is my error.
> Traceback (most recent call last):
> File
> "C:/PROGRA~2/QGIS3~1.4/apps/qgis-ltr/./python/plugins\processing\algs\qgis\TinInterpolation.py",
> line 187, in processAlgorithm
> writer.writeFile(feedback)
> Exception: unknown
> Execution failed after 16.94 seconds
> Any thoughts please?
> Dave
