[Qgis-user] qgis 3.11 with grass79dev, debian buster, plugin/processing toolbox
Christian Yrrman yrrman at gmail.com
Sat Dec 21 07:54:41 PST 2019
Hi All,
just for the records (as of Dec 2019) with regard to grass79dev integration
into qgis3.11 not working - I found a posting in
https://gis.stackexchange.com/questions/304245/grass-processing-not-working-on-qgis
by markusN from Dec 2018, suggesting to symlink grass versions > 7.4 to 7.4
(i.e. ln -fs grass79 grass74), as qgis seems to look for grass74, 72, 70.
For me this did the trick, :-) - a "thank you" to markusN.
Best and season's greetings
Chris
On Fri, Dec 6, 2019 at 7:15 PM Christian Yrrman <yrrman at gmail.com> wrote:
> Hi All,
> I'm a bit stuck with GRASS integration into QGIS. I have both qgis3.11 and
> grass79 compiled from git into /scratch/opt/ on a linux debian buster
> machine.
> On startup, the plugin seems to load fine from
> /scratch/opt/lib/qgis//plugins/libgrassplugin7.so
> When I enable the plugin, I can create new mapsets etc.
> However the grass tools in the processing toolbox (that I would like to
> use in the first place) do not work ("grass not found" error).
> So seems like a PATH problem but where can I track that down? Is there a
> logging option that I could check?
> Thanks and best regards
> Chris
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191221/31bd1a6e/attachment.html>
