[Qgis-user] ModuleNotFoundError: No module named 'txt2tags'
Jorge Gustavo Rocha
jgr at geomaster.pt
Sun Feb 3 23:15:32 PST 2019
Use *python2* instead of *python*.
The header should be: */usr/bin/python2* instead of */usr/bin/python*.
Regards,
Jorge
Às 04:46 de 04/02/19, JIA Pei escreveu:
> Thank you Avenida....
> My current *txt2tags* file is ALREADY like that. Did you miss anything?
> ➜ ~cat /usr/bin/txt2tags
> #! /usr/bin/python
> import txt2tags
> txt2tags.exec_command_line()
> On Sun, Feb 3, 2019 at 3:42 PM Jorge Gustavo Rocha <jgr at geomaster.pt
> <mailto:jgr at geomaster.pt>> wrote:
> Hi Jia,
> For a quick work around, just edit the file and change the header:
> sudo vi /usr/bin/txt2tags
> #! /usr/bin/python2
> import txt2tags
> I hope that helps,
> Jorge Gustavo
> Às 13:52 de 03/02/19, JIA Pei escreveu:
>> Hi, all:
>> I'm using *Ubuntu 18.04*. And I'm quite sure I've *txt2tags* (an
>> *EXE*) installed. And I also successfully installed *txt2tags*
>> Python module from https://github.com/txt2tags/txt2tags .
>> However, I still failed to build QGIS with the following *ERROR*
>> messages??? Any suggestions?
>> make[2]: Entering directory '....../QGIS/build'
>> [ 0%] Building ....../QGIS/build/doc/INSTALL from
>> ....../QGIS/doc/INSTALL.t2t
>> cd ....../QGIS/build/doc && /usr/bin/txt2tags
>> --encoding=utf-8 -o....../QGIS/build/doc/INSTALL -t txt
>> Traceback (most recent call last):
>> File "/usr/bin/txt2tags", line 3, in <module>
>> import txt2tags
>> doc/CMakeFiles/t2tdoc.dir/build.make:66: recipe for target
>> 'doc/INSTALL' failed
>> make[2]: *** [doc/INSTALL] Error 1
>> make[2]: Leaving directory '....../QGIS/build'
>> CMakeFiles/Makefile2:1090: recipe for target
>> 'doc/CMakeFiles/t2tdoc.dir/all' failed
>> make[1]: *** [doc/CMakeFiles/t2tdoc.dir/all] Error 2
>> make[1]: Leaving directory '....../QGIS/build'
>> Makefile:165: recipe for target 'all' failed
>> make: *** [all] Error 2
>> Pei JIA, Ph.D.
>> Email: jp4work at gmail.com <mailto:jp4work at gmail.com>
>> cell in Canada: +1 778-863-5816
>> cell in China: +86 186-8244-3503
>> Welcome to Vision Open
>> http://www.visionopen.com
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Logo* Geomaster, LDA*
> *VENHA DESCOBRIR O CAMINHO DO OPEN SOURCE CONNOSC**O
> Avenida Barros e Soares
> N.º 423, 4715-214 Braga
> VAT/NIF510 906 109
> Phone +351 253 680 323
> Site geomaster.pt <http://geomaster.pt>
> GPS 41.53322, -8.41929
> Jorge Gustavo Rocha
> CTO
> Mobile +351 910 333 888
> Email jgr at geomaster.pt <mailto:jgr at geomaster.pt>
> Pei JIA, Ph.D.
VAT/NIF510 906 109
Jorge Gustavo Rocha
CTO
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190204/f3ed5a7f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190204/f3ed5a7f/attachment-0001.png>
