[Qgis-user] [QGIS-Server] WFS-T
DelazJ
delazj at gmail.com
Mon Feb 4 12:53:02 PST 2019
Le lun. 4 févr. 2019 à 18:37, Jonathan Moules <jonathan-lists at lightpear.com>
a écrit :
> Hi,
> Well, taking the error at face value, it seems to be complaining that you
> have:
> *REQUEST=Transaction*
> in the URL. Which is odd because that's exactly what it should be (looking
> at the 1.0.0 spec).
> But at the bottom of your error, it says:
> 10:15:17 WARNING [9148]: Service WFS 1.0.0 not found, returning default
> So I'd suggest that QGIS Server doesn't support transactions for WFS 1.0.0
> (Transactions support is Optional). Except the QGIS docs say they do
> support Transaction:
> https://docs.qgis.org/2.8/en/docs/user_manual/working_with_ogc/ogc_server_support.html
> - and WFS 1.0.0 seems to be the only version supported by QGIS so... are
> the errors misleading? (I can't seem to readily find that page for QGIS
> 3.4).
> Nobody should be using QGIS 2.8 today so I guess you were referring to the
2.18 link ie,
https://docs.qgis.org/2.18/en/docs/user_manual/working_with_ogc/ogc_server_support.html
and for the 3.4 link, it's from
https://docs.qgis.org/3.4/en/docs/user_manual/working_with_ogc/server/index.html
Regards,
Harrissou
The GetCapabilities of the server will tell you if it supports Transaction.
> Maybe someone who knows QGIS Server (I'm just basing this reply off the
> spec and your error) can comment.
> Cheers,
> Jonathan
> On 2019-02-01 09:57, Bernhard Ströbl wrote:
> Hi all,
> I try to make an INSERT to QGIS-Server using WFS-T. But every insert fails
> with the server returning "Please check the value of the REQUEST parameter"
> This is the QGIS-server log output (anonymised):
> 10:15:17 INFO Server[9148]: ******************** New request
> 10:15:17 INFO Server[9148]: SERVER_NAME***
> 10:15:17 INFO Server[9148]: REQUEST_URI/wms/pmt?SERVICE=WFS
> 10:15:17 INFO Server[9148]: REMOTE_ADDR10.***.***.**
> 10:15:17 INFO Server[9148]: CONTENT_TYPEtext/xml
> 10:15:17 INFO Server[9148]: HTTP_USER_AGENTMozilla/5.0 QGIS/3.4.3-Madeira
> 10:15:17 INFO Server[9148]: MAP:/var/www/wms/karten/pmt.qgs
> 10:15:17 INFO Server[9148]: REQUEST:Transaction
> 10:15:17 INFO Server[9148]: REQUEST_BODY:<Transaction xmlns=
> "http://www.opengis.net/wfs" <http://www.opengis.net/wfs> version="1.0.0"
> service="WFS" xsi:schemaLocation="http://www.qgis.org/gml
> https://pmt-map.jena.de:443/wms/pmt?SERVICE=WFS&REQUEST=DescribeFeatureType&VERSION=1.0.0&TYPENAME=projekt_pt"
> <http://www.qgis.org/gmlhttps://pmt-map.jena.de:443/wms/pmt?SERVICE=WFS&REQUEST=DescribeFeatureType&VERSION=1.0.0&TYPENAME=projekt_pt>
> xmlns:gml="http://www.opengis.net/gml" <http://www.opengis.net/gml>
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> <http://www.w3.org/2001/XMLSchema-instance>><Insert xmlns=
> "http://www.opengis.net/wfs" <http://www.opengis.net/wfs>><projekt_pt
> xmlns="http://www.qgis.org/gml" <http://www.qgis.org/gml>><geometry xmlns=
> "http://www.qgis.org/gml" <http://www.qgis.org/gml>><gml:Point
> srsName="EPSG:25832"><gml:coordinates ts=" "
> cs=",">681077.95823665894567966,5643649.18793503474444151</gml:coordinates></gml:Point></geometry></projekt_pt></Insert></Transaction>
> 10:15:17 INFO Server[9148]: SCHEMALOCATION:http://www.qgis.org/gml
> 10:15:17 INFO Server[9148]: SERVICE:WFS
> 10:15:17 INFO Server[9148]: VERSION:1.0.0
> 10:15:17 INFO Server[9148]: Request finished in 1 ms
> the apache error log says:
> QNetworkDiskCache::prepare() unable to open temporary file
> any help appreciated
> System: QGIS-Server 3.4.4 on Ubuntu/Apache, WFS-Client QGIS Desktop 3.4.3
> Bernhard
> __________ Information from ESET Mail Security, version of virus signature
> database 18802 (20190201) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190204/da11a68e/attachment.html>
