[Qgis-user] model that runs bat file to obtain vector layer
Nyall Dawson
nyall.dawson at gmail.com
Mon Feb 4 14:27:08 PST 2019
On Tue, 5 Feb 2019 at 06:06, Reginald <Reginald.Carlier at ingelmunster.be> wrote:
> Thanks Nicolas,
> You have me some hints on how to do it.
> The bat file was created according to the code of Michel Stuyts.
> I adapted it to work with SSL and I guess I only have to do
> call C:\Osgeo4W64\bin\py3_env.bat # this will make the GDAL SRS database
> available
> os.system([("cmd", "extractwfsdata.bat")])
> My question was in fact if it is posible to run a bat file or a python
> script from within the QGIS modeler tool.
Yes - in both cases you'd need to wrap your python script (or a python
script calling the batch file) into a "processing algorithm". There's
a template for this available from the Processing toolbox. Click the
Python button in the toolbar, and then select "Create Script from
Template".
Nyall
> Any idea?
> Regards,
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
