[Qgis-user] spatialite with update trigger seems to result in 'unselectable' geometry
Janneke van Dijk janneke.qgis at gmail.com
Tue Feb 5 04:02:45 PST 2019
Dear list,
Could anybody maybe help me understand what I'm doing wrong (or even
tell me that what I want to do can't be done)?
This is what I'm trying to do. I have a spatialite layer with columns
north and east which contain coordinates in decimal degrees. I would
like to be able to change the coordinates in the attribute table and
have the trigger take care of updating the geometry based on the new
coordinates. The following update statement, using the DB manager:
UPDATE watersources SET geom = Transform(MakePoint(east, north, 4326),
32638) WHERE id=1678;
works as expected: after saving the edits, the point will appear in the
new location based on the changed coordinates, and I can select the
point in the map and I can use the identify button to open the form at
that point. If (by way of a test) I use the same statement inside a
trigger (and I realise this is not ultimately how I would want to define
the trigger, but I'm trying to understand the different effects of the
same update statement):
CREATE TRIGGER update_geom AFTER UPDATE ON watersources BEGIN
END
I can change the coordinates, save the changes and stop editing, the
point will indeed appear in the new location, but I can't select it in
the map, or use the identify feature to open the form. I can locate it
in the attribute table and select it and use 'zoom to selected' after
which the map will center on the selected point (but not zoom in). After
running the update statement 'stand alone' again, all works as expected
again.
Does anyone have an idea why this could happen? Has anyone tried doing
something similar in spatialite and gotten it to work? Any tips on how I
could troubleshoot this? I have a test file with only 4 points that I
could share if that helps. Using QGIS 3.4.4. on Windows 10.
Any help/thoughts will be appreciated!
Thanks,
Janneke
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190205/6c8e0d7d/attachment.html>
