[Qgis-user] PIN # LookUp Help?
Alexandre Neto senhor.neto at gmail.com
Tue Feb 19 11:23:18 PST 2019
For QGIS 2.x you can use the quick finder plugin
https://plugins.qgis.org/plugins/quickfinder/
Which overlaps with qgis 3 locator bar functionality.
Alexandre Neto
A ter, 19/02/2019, 13:53, Randal Hale <rjhale at northrivergeographic.com>
escreveu:
> I did a quick glance at their website - I assume you've downloaded the
> data.
> If you have the data downloaded and open in QGIS you can also use the
> Select Features By Value Tool (its on the attributes toolbar and you can
> also tap F3 on your keyboard) and enter the pin number in the appropriate
> field and it should autocomplete. From there you can zoom, flash, etc the
> parcel. I think someone also mentioned the "locate tool" in the bottom left
> corner of QGIS.
> As far as using metasearch - that depends on whether they've published a
> catalog service - but having the data should work just fine.
> Good Luck!
> Randy
> On 2/18/19 2:15 PM, Craig C. Horvath wrote:
> Hello,
> This site, that is located/used by Will County Illinois:
> https://gisapp.willcountyillinois.com/Html5Viewer/Index.html?viewer=Data_Viewer
> If you type in a PIN in the search box, you can go directly to the parcel:
> 11-04-34-210-002-0000
> Once you get to the parcel, you can then Look up Tax records information,
> etc.
> I have utilized the County database tools to create my own QGIS map.  I
> have utilized all of the datasets.  However, I am unable to do the
> following:
> 1) In my map, I am unable to type in Addresses or PINS in order to Go
> Directly To a specific parcel.  I have to move the map around until I find
> it.    How do you use a Find function to type in an address or PIN to go
> directly to the parcel?
> 2) The County has stated that I should be able to use "Meta Search'
> functionality in order to be able to see Tax Records information from my
> Qgis map, similar to the same fashion that the County site works.  Would
> anyone now how I can link up the data somehow in order to do this?
> Craig
> Qgis-user mailing listQgis-user at lists.osgeo.org
> Randal Halerjhale at northrivergeographic.comhttps://www.northrivergeographic.com
> (423)653-3611
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190219/ff0b143f/attachment.html>
