[Qgis-user] [Qgis-server 3.4] Serve project with custom Python expression
Dominique Lyszczarz domlysz at gmail.com
Wed Feb 27 04:26:20 PST 2019
Thank you for your help,
Unfortunately QGIS_CUSTOM_CONFIG_PATH does not solve the issue, I've the
feeling that this variable has been removed since QGIS3, it's not listed in
the docs and qgis-server log file does not report it, even if it was set in
Apache conf. Moreover, setting QGIS_OPTIONS_PATH to profile folder works
crorrectly, I can see in the log that the init file was found and some
variable like QGIS_SERVER_PARALLEL_RENDERING have been correctly overridden
by the init configuration.
Le mer. 27 févr. 2019 à 12:21, Alessandro Pasotti <apasotti at gmail.com> a
écrit :
> On Wed, Feb 27, 2019 at 9:51 AM Dominique Lyszczarz <domlysz at gmail.com>
> wrote:
>> Hi,
>> I'm trying to serve a project that use data-defined properties with an
>> expression using a custom Python function. Custom Python functions for
>> expression engine are stored in user's profile folder
>> (QGIS3/profiles/default/python/expression), so I've tryied to set up FCGI
>> environment variable (Apache) as referred in the doc (
>> https://docs.qgis.org/testing/en/docs/user_manual/working_with_ogc/server/config.html)
>> FcgidInitialEnv QGIS_OPTIONS_PATH
>> "/home/user/.local/share/QGIS/QGIS3/profiles/default"
>> But it does not seems to works, any idea ?
> QGIS_OPTIONS_PATH is  the path to QGIS3.ini (which contains the user
> settings), not the path to the profile folder.
> QGIS_CUSTOM_CONFIG_PATH is what are you probably looking for.
> Hope this helps.
>> Thanks in advance
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alessandro Pasotti
> w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190227/a934cc2d/attachment.html>
