[Qgis-user] Extend feature not working in 3.6.0?
Luca Manganelli luca.manganelli at comune.trento.it
Wed Feb 27 23:42:12 PST 2019
I have explained badly. The documentation explains the EXTEND command
cleary; that I don't understand is how to TRIM. :-)
Il giorno gio 28 feb 2019 alle ore 08:14 DelazJ <delazj at gmail.com> ha
scritto:
> Hi,
> Le jeu. 28 févr. 2019 à 08:11, Luca Manganelli <
> luca.manganelli at comune.trento.it> a écrit :
>> Thank you. I understood how to EXTEND (but the documentation wasn't
>> explain too well),
> Luca, would you mind proposing a fix for what you missed in the proposed
> documentation?
> Thanks,
> Harrissou
>> but not how to TRIM... :-)
>> Il giorno gio 28 feb 2019 alle ore 07:42 Loïc Bartoletti <
>> lbartoletti at tuxfamily.org> ha scritto:
>>> Hi Luca,
>>> You must activate segment snapping for this tool to work.
>>> The documentation is ready but not available online. You can see the two
>>> PR for this documentation:
>>> https://github.com/qgis/QGIS-Documentation/pull/3171/files
>>> https://github.com/qgis/QGIS-Documentation/pull/3343/files
>>> Regards
>>> Loïc
>>> Le 28/02/2019 à 07:33, Luca Manganelli a écrit :
>>> I've tried the new extend tool. I've followed these steps:
>>> 1. Create a new temporary multiline string layer;
>>> 2. Created two new lines;
>>> 3. Clicked on Extend/Trim tool;
>>> 4. I've moved over feature, clicked on it, it seems that is not working
>>> Qgis-user mailing listQgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Luca Manganelli
>> Assistente informatico
>> Servizio Innovazione e Sistemi digitali
>> Via Ezio Maccani 148
>> 38121 Trento (TN)
Luca Manganelli
38121 Trento (TN)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190228/ce844390/attachment.html>
