[Qgis-user] python qgis 3 adding features fails partly
Michel Stuyts
michel.stuyts at edegem.be
Thu Feb 28 01:34:24 PST 2019
You can add an empty table to QGIS but it depends on the definition of your geometry column.
This table can be added:
CREATE TABLE public.test
id oid NOT NULL,
naam text COLLATE pg_catalog."default" NOT NULL,
geom geometry(Point,31370),
CONSTRAINT test_pkey PRIMARY KEY (id)
This table cannot be added:
id oid NOT NULL,
geom geometry(Geometry,31370),
The easiest way to create the new table is to use the DB Manager.
Michel
-----Oorspronkelijk bericht-----
Van: Qgis-user <qgis-user-bounces at lists.osgeo.org> Namens Reginald
Verzonden: donderdag 28 februari 2019 9:22
Aan: qgis-user at lists.osgeo.org
Onderwerp: Re: [Qgis-user] python qgis 3 adding features fails partly
I'm still scratching my head over this one.
As a test I created a table 'test' in postgis:
id: pkey type oid
naam: type text
geom: type geometry
select updateGeometrySrid('test','geom',31370) # assigning projected CRS to geometry
When I try to add this table to qgis using the database explorer I get an error because there is no geometry in the table.
So I was wondering if it is impossible to add an empty postgis table to qgis?
Regards,
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
