[Qgis-user] After deleting points, attribute rows persist
DelazJ
delazj at gmail.com
Mon Jan 7 07:25:44 PST 2019
Hi Micha,
The Node Tool is not meant to remove features, but to edit/remove their
geometries. Your feature persists in your dataset through their attributes
and you can later use the "Add part" tool to create a new geometry.
https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html#vertex-tool
For full deletion (data + geometry), you should use the the "Delele
selected" tool, with a red bin.
Regards,
Harrissou
Le lun. 7 janv. 2019 à 16:15, Micha Silver <tsvibar at gmail.com> a écrit :
> Hi Alex:
> Linux Mint 19
> gdal 2.2.3
> QGIS 3.4.3
> Just out of curiosity, I did the same on a debian buster machine (QGIS
> 2.18) and found the same: deleting vertices (with the node tool) on a point
> vector layer does not delete the attribute rows.
> On 1/6/19 11:38 PM, Alexandre Neto wrote:
> What's your platform?
> What's the version of gdal?
> Thanks,
> Alex Neto
> A dom, 6/01/2019, 12:55, Micha Silver <tsvibar at gmail.com> escreveu:
>> I have found that after deleting some points in both a shapefile and a
>> geopackage layer, the attribute rows remain in the table (with null
>> geometry). Is this expected? I'm using 3.4.3, and I don't remember that
>> being so in earlier versions.
>> I removed the "phantom" rows by selecting by expression: '$geometry is
>> null' and then deleting. Still the behavior was surprising. I hope this is
>> not a resurrection of https://issues.qgis.org/issues/11007 ??
>> Thanks
>> Micha Silver
>> Ben Gurion Univ.
>> Sde Boker, Remote Sensing Lab
>> cell: +972-523-665918
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
> Micha Silver
> Ben Gurion Univ.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190107/ff8f70f3/attachment.html>
