[Qgis-user] [Qgis-community-team] training manual QGIS 3
DelazJ
delazj at gmail.com
Wed Jan 9 10:01:08 PST 2019
Hi Janneke,
I guess you are talking about
https://github.com/janneke-qgis/QGIS-Documentation/pull/1 which is
unfortunately a pull-request against your own branch and not the upstream
one. This is a trap we all fall in at the beginning and mentioned at
https://docs.qgis.org/testing/en/docs/documentation_guidelines/first_contribution.html#share-your-changes-via-pull-request
What you have to do is also explained in the page I linked above (if ever
not clear, let us know, we'll try to improve it) but in short:
1. Go to https://github.com/qgis/QGIS-Documentation/pulls
2. Press "New pull request"
3. Click "Compare accross forks" and select your repo in the head fork drop
down menu and then the your branch (janneke-qgis-patch-1 in this case)
4. Press "Create pull request"
5. And you are done!
H.
Le mer. 9 janv. 2019 à 18:46, Janneke van Dijk <janneke.qgis at gmail.com> a
écrit :
> Hi Alexandre and Harrissou (and others),
> I'm trying to feel my way through the contribution thing and github by
> starting with some small remarks/changes I suggested myself. I think I have
> just made an edit and created a pull request - it tells me 'This branch
> has no conflicts with the base branch'. Not sure how to proceed from here.
> Is this enough from my side?
> Thanks for some guidance....
> Janneke
> On 07/01/2019 23:27, Alexandre Neto wrote:
> Screenshots shouldn't be a blocker, you can take screenshots using
> windows. Then, if we have time, we can replace windows screenshots later.
> A seg, 7/01/2019, 18:17, Janneke van Dijk <janneke.qgis at gmail.com>
> escreveu:
>> Yes, I would be up for learning how to do it. I remember once upon a time
>> trying to get started and somehow getting stranded before I got anywhere.
>> Partly because I couldn't get linux to work on VM on my laptop so I
>> couldn't do the screen shots.
>> On 07/01/2019 17:39, Alexandre Neto wrote:
>> Some of those changes are quite small. Would you be interested in
>> learning how to fix it yourself?
>> A seg, 7/01/2019, 14:37, Alexandre Neto <senhor.neto at gmail.com> escreveu:
>>> Actually, someone already did it. Thanks!!
>>> escreveu:
>>>> I can do it.
>>>> A seg, 7/01/2019, 13:43, Janneke van Dijk <janneke.qgis at gmail.com>
>>>> escreveu:
>>>>> I've registered all that I've noticed, I just didn't manage to tag
>>>>> them with training manual. Should I do that or is that someone else who
>>>>> adds the labels?
>>>>> Janneke
>>>>> On 07/01/2019 00:42, Alexandre Neto wrote:
>>>>> Better duplicated issues than missing ones . So please report whatever
>>>>> you feel that is a bug, or a possible improvement. That way we won't forget.
>>>>> Thanks!
>>>>> A dom, 6/01/2019, 10:07, Janneke van Dijk <janneke.qgis at gmail.com>
>>>>> escreveu:
>>>>>> Hi Harrissou,
>>>>>> Getting ready to at least list my observations. Do I understand it
>>>>>> correctly that whatever is not mentioned in [2] is not being addressed?
>>>>>> Quite a few of my remarks will also related to updating screenshots, which
>>>>>> I think has also been mentioned as a general issue somewhere - should I
>>>>>> still list them separately?
>>>>>> Thanks for your assistance,
>>>>>> Janneke
>>>>>> On 05/01/2019 13:33, DelazJ wrote:
>>>>>> Hi Janneke,
>>>>>> Thanks for your tests. And indeed the training manual update is a
>>>>>> work in progress and maybe could you publish your remarks as issue reports
>>>>>> in the doc repository [0] so that we took them into consideration as we go.
>>>>>> You are right about the missing data, there was a pull request [1] to
>>>>>> integrate these data we forgot to merge. Done now! Download the dataset
>>>>>> again, please.
>>>>>> Note that we are reviewing initial lessons and have some pending
>>>>>> updates for both lessons [2] and corresponding data [3]. Tests and
>>>>>> feedbacks are more than welcome. Thanks!
>>>>>> [0] https://github.com/qgis/QGIS-Documentations/issues
>>>>>> [1] https://github.com/qgis/QGIS-Training-Data/pull/15
>>>>>> [2]
>>>>>> https://github.com/qgis/QGIS-Documentation/pulls?q=is%3Apr+is%3Aopen+label%3A%22Training+Manual%22
>>>>>> [3] https://github.com/qgis/QGIS-Training-Data/pull/17
>>>>>> Regards,
>>>>>> Harrissou
>>>>>> Le jeu. 3 janv. 2019 à 13:22, Janneke van Dijk <
>>>>>> janneke.qgis at gmail.com> a écrit :
>>>>>>> Dear all,
>>>>>>> I'm currently going through the QGIS 3 training manual
>>>>>>> (https://docs.qgis.org/testing/en/docs/training_manual/) using QGIS
>>>>>>> 3.4.3 and documenting any changes that would still need attention. I
>>>>>>> understand that it's a work in progress and hope/plan to contribute
>>>>>>> a
>>>>>>> bit in a later stage. What is complicating matters is that the data
>>>>>>> that
>>>>>>> I downloaded (QGIS-Training-Data-2.0.zip) does not contain all the
>>>>>>> layers that are mentioned (so far schools, restaurants,
>>>>>>> network_analysis
>>>>>>> folder and possibly some more that I may have skipped). Is there a
>>>>>>> complete/up-to-date data set available? Where can I find it?
>>>>>>> Thanks for any suggestions,
>>>>>>> Janneke
>>>>>>> _______________________________________________
>>>>>>> Qgis-user mailing list
>>>>>>> Qgis-user at lists.osgeo.org
>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> Qgis-community-team mailing list for organizing community resources
>>>>>> such as documentation, translation etc..
>>>>>> Qgis-community-team at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
>>>>> Alexandre Neto
>>>>> @AlexNetoGeo
>>>>> http://sigsemgrilhetas.wordpress.com
>>>>> http://gisunchained.wordpress.com
>>>> Alexandre Neto
>>>> @AlexNetoGeo
>>> Alexandre Neto
>>> @AlexNetoGeo
>> Alexandre Neto
>> @AlexNetoGeo
> Alexandre Neto
> @AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190109/2991e745/attachment-0001.html>
