[Qgis-user] Diameter of buffers
Herbert Faber
herbert.faber at outlook.com
Mon Jan 14 06:21:07 PST 2019
Dear all,
When I put ring buffers arond dot objects, the diameter doesn't come out as I would expect.
For instance, when I try to make ring buffer with a distance of 100 meter and 25 segments around a dot object. The diameter of the buffer turns out to be approx 126 m when I measure it with the ruler tool.
What am I doing wrong?
I work with OSM Standard map in EPSG:3857 - WGS 84 / Pseudo-Mercator - projection and so are my shape files.
Best regards,
Herbert Faber
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190114/73ed1913/attachment.html>
