[Qgis-user] Featured plugins: nominations
Nyall Dawson
nyall.dawson at gmail.com
Wed Jan 23 14:55:55 PST 2019
On Thu, 24 Jan 2019 at 07:47, Régis Haubourg <regis.haubourg at gmail.com> wrote:
> Hi all,
> after a few training sessions, here are the plugins I end up recommanding each time for QGIS as a corporation shared tool, where the most common and basic use case is: "pick layers, find a location, create a mask on the area, print and go do your job"
> - Menu from project : https://plugins.qgis.org/plugins/menu_from_project/
> Simply the best tool I know to create a serie of layer shortcuts, with only the burden of maintaining classical project files.
Sounds like a great idea!
> It also offers a chance to display metadatas and use restriction before picking layers in QGIS.
FYI - this is also visible in the browser panel, if you toggle on the
"i" properties display panel. In 3.6 you can also "expand" out
projects in the browser, to see their layers and structure directly
from inside browser (including metadata and layer previews when the
properties panel is opened)
Nyall
> - Mask plugin : https://plugins.qgis.org/plugins/mask/
> create simple masks that can filter labels not inside the masked area. Working with Atlas too. Same thing, it should be a core feature. Making it play with locator bar for place search use case would be nice. In QGIS 2, it used to play with OSM place search plugin and allowed to create a mask from a place search outputing a polygon.
> - Memory Layer Saver. Can't live without (well trying to thanks to auxiliary data now)
> - QGIS2ThreeJS. No comment. Just awesome
> Regards
> Régis
> Le mar. 22 janv. 2019 à 18:23, Paolo Cavallini <cavallini at faunalia.it> a écrit :
>> Hi all,
>> please let us know whether there are plugins that you believe should be
>> listed as featured, and are not. Just send a short description of why
>> they should listed.
>> Also, please warn us if there are featured plugins that should be delisted.
>> http://plugins.qgis.org/plugins/featured/
>> All the best, and thanks.
>> Paolo Cavallini - www.faunalia.eu
>> QGIS.ORG Chair:
>> http://planet.qgis.org/planet/user/28/tag/qgis%20board/
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
