[Qgis-user] Problems QGIS 3.4 - Size fount and export to PDF - Help
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Mon Jan 28 16:23:33 PST 2019
Hi Niall,
Just to be clear, my problems were only on the layout window. It was ok when I exported it to PDF.
Windows 10 OSGeo4w64.
Nicolas
> Le 28 janv. 2019 à 18:53, Nyall Dawson <nyall.dawson at gmail.com> a écrit :
> On Sun, 27 Jan 2019 at 12:42, Wilmer Orlando Martinez Bojaca
> <womartinezb at unal.edu.co> wrote:
>> Hi!
>> Well, with which resolution you export the layout?
>> In my case when I change the fount on the project window, the change immediately can see it on the layout window, but when I try change the fount in the legend on the layout window, anything change. I try too restart the software but happen the same thing, the fount doesn´t change.
>> I have Mojave Mac 64x.
> Which OSX installer are you using?
> Nyall
>>> On Sat, Jan 26, 2019 at 9:33 PM Nicolas Cadieux <nicolas.cadieux at archeotec.ca> wrote:
>>> Windows 10 64, fresh QGIS install with OSGeo4w64 with latest version (not nightly build)
>>> Nicolas
>>>> Le 26 janv. 2019 à 21:31, Nyall Dawson <nyall.dawson at gmail.com> a écrit :
>>>> On Sun, 27 Jan 2019 at 12:16, Nicolas Cadieux
>>>>> Hi,
>>>>> I just noticed today that changing the font type and size does not change in the layout window even after a refresh. I do see it if I export it as a PDF. Looks like a bug...
>>>> Are you on OSX?
>>>> Nyall
>>>>> Nicolas
>>>>> Le 26 janv. 2019 à 19:16, Wilmer Orlando Martinez Bojaca <womartinezb at unal.edu.co> a écrit :
>>>>> Hi everyone!
>>>>> I have two problems with my QGIS, it looks so simple
>>>>> 1. When I try to change the fount size in the legend, the program doesn't works. Thats mean, I can change the size (i.e. 12 to 10) but when I accept (press ok) the size is the same. I'm tried many times but never change anything.
>>>>> 2. When I try to export the project to PDF, the final document appear empty (is a blank sheet) without any information, absolutely nothing. In this step I always select print like raster with 3000 ppp like export resolution.
>>>>> I have QGIS 3.4 on Mac.
>>>>> Anybody could help me please? Maybe is a simple set up.
>>>>> Gracias. Saludos,
>>>>> Orlando Martínez Bojacá
>>>>> Profesional Especializado - Proyectos Productivos - FENSUAGRO
>>>>> Zootecnista - Universidad Nacional de Colombia
>>>>> Candidato MSc en Geomática - Universidad Nacional de Colombia
>>>>> Tel. +57 3505731220
>>>>> Skype. womartinezb
>>>>> Linkedin. Orlando Martínez Bojacá
>>>>> Antes de imprimir este correo piense bien si es necesario hacerlo. ¡El medio ambiente es cosa de todos!
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
