[Qgis-user] Batch-Mode-Error in Building Pyramids QGIS3.x
Elstermann, Mike
Mike.Elstermann at itc-halle.de
Wed Jul 17 05:54:52 PDT 2019
Hello, everybody,
One of our customers uses QGIS 3.x to create pyramids in batch mode. Without batch mode, i.e. individual TIFs, it works fine, but in batch mode the following messages appear:
Python-Fehler
2019-07-05T14:17:01 WARNING Traceback (most recent call last):
File "C:/PROGRA~1/QGIS3~1.8/apps/qgis/./python/plugins\processing\gui\wrappers.py", line 209, in widgetValue
return self.value()
File "C:/PROGRA~1/QGIS3~1.8/apps/qgis/./python/plugins\processing\gui\wrappers.py", line 1012, in value
return self.widget.value()
AttributeError: "BatchInputSelectionPanel" object has no attribute "value"
Meldungen
2019-07-05T14:17:01 WARNING Python-Fehler : Ein Fehler trat bei der Ausführung von Python-Code auf: Mehr Details im Protokoll (Python-Fehler).
2019-07-05T14:17:01 WARNING Wrong or missing parameter value: Eingabelayer (row 1)
Verarbeitung
2019-07-05T14:17:02 CRITICAL Traceback (most recent call last):
File "C:/PROGRA~1/QGIS3~1.8/apps/qgis/./python/plugins\processing\algs\gdal\GdalAlgorithm.py", line 129, in processAlgorithm
commands = self.getConsoleCommands(parameters, context, feedback, executing=True)
File "C:/PROGRA~1/QGIS3~1.8/apps/qgis/./python/plugins\processing\algs\gdal\gdaladdo.py", line 117, in getConsoleCommands
raise QgsProcessingException(self.invalidRasterError(parameters, self.INPUT))
_core.QgsProcessingException: Konnte Quelllayer für INPUT nicht laden: keine Wert für Parameter angegeben
Python-Warnungen
2019-07-05T14:15:53 WARNING warning:C:\PROGRA~1\QGIS3~1.8\apps\Python37\lib\site-packages\requests\status_codes.py:18: DeprecationWarning: invalid escape sequence \o
traceback: File "", line 1, in
File "C:/PROGRA~1/QGIS3~1.8/apps/qgis/./python\qgis\utils.py", line 354, in startPlugin
if not _startPlugin(packageName):
File "C:/PROGRA~1/QGIS3~1.8/apps/qgis/./python\qgis\utils.py", line 334, in _startPlugin
plugins[packageName] = package.classFactory(iface)
File "C:/Users/senst/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\Hqgis-master\__init__.py", line 35, in classFactory
from .hqgis import Hqgis
File "C:/PROGRA~1/QGIS3~1.8/apps/qgis/./python\qgis\utils.py", line 737, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File "", line 983, in _find_and_load
File "", line 967, in _find_and_load_unlocked
File "", line 677, in _load_unlocked
File "", line 728, in exec_module
File "", line 219, in _call_with_frames_removed
File "C:/Users/senst/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\Hqgis-master\hqgis.py", line 31, in
from .GetMapCoordinates import GetMapCoordinates
File "C:/Users/senst/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\Hqgis-master\GetMapCoordinates.py", line 6, in
import requests,json
File "C:\PROGRA~1\QGIS3~1.8\apps\Python37\lib\site-packages\requests\__init__.py", line 114, in
from .models import Request, Response, PreparedRequest
File "C:\PROGRA~1\QGIS3~1.8\apps\Python37\lib\site-packages\requests\models.py", line 43, in
from .status_codes import codes
File "", line 724, in exec_module
File "", line 860, in get_code
File "", line 791, in source_to_code
Does anyone have an idea?
THX, mikeE.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190717/4feda90d/attachment.html>
