[Qgis-user] Using QgsAuthManager
Paul Wittle paul.wittle at dorsetcouncil.gov.uk
Wed Jul 24 05:19:46 PDT 2019
I'm trying to use python to assign an authentication configuration to a WMS layers that I'm adding. I have been using the following guide https://docs.qgis.org/3.4/en/docs/pyqgis_developer_cookbook/authentication.html#leave-authcfg-expansion-to-qgsauthmanager.
I had to update a few bits as I think some of the code maybe a little out of date but I managed to get it all working right down to the section I've linked to.
The line  "rlayer = QgsRasterLayer(quri.encodedUri(), 'states', 'wms')" was resulting in an unexpected type error as encodedUri returns a QByteArray rather than a string but I just wrapped it in str(quri.encodedUri()) and that now returns as a string.
The only trouble is that the getCapabilities statement fails and no layer is added.
Does anyone know how I can see whether the AuthManager attempted to expand the authcfg and send credentials as I suspect it didn't in my case?
Sorry if this email is too much along the developer lines for this mailing list but it is only plugin development rather than actual development of the application itself so I thought I'd try my luck.
Thanks,
Paul
This e-mail and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. It may contain unclassified but sensitive or protectively marked material and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All traffic may be subject to recording and/or monitoring in accordance with relevant legislation. Any views expressed in this message are those of the individual sender, except where the sender specifies and with authority, states them to be the views of Dorset Council. Dorset Council does not accept service of documents by fax or other electronic means. Virus checking: Whilst all reasonable steps have been taken to ensure that this electronic communication and its attachments whether encoded, encrypted or otherwise supplied are free from computer viruses, Dorset Council accepts no liability in respect of any loss, cost, damage or expense suffered as a result of accessing this message or any of its attachments. For information on how Dorset Council processes your information, please see www.dorsetcouncil.gov.uk/416433
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190724/3a8864f4/attachment.html>
