[Qgis-user] Using QgsAuthManager
DelazJ delazj at gmail.com
Wed Jul 24 15:24:57 PDT 2019
Le mer. 24 juil. 2019 à 14:20, Paul Wittle <paul.wittle at dorsetcouncil.gov.uk>
a écrit :
> Hi,
> I’m trying to use python to assign an authentication configuration to a
> WMS layers that I’m adding. I have been using the following guide
> https://docs.qgis.org/3.4/en/docs/pyqgis_developer_cookbook/authentication.html#leave-authcfg-expansion-to-qgsauthmanager
> I had to update a few bits as I think some of the code maybe a little out
> of date but I managed to get it all working right down to the section I’ve
> linked to.
> The line  “rlayer = QgsRasterLayer(quri.encodedUri(), 'states', 'wms')”
> was resulting in an unexpected type error as encodedUri returns a
> QByteArray rather than a string but I just wrapped it in
> str(quri.encodedUri()) and that now returns as a string.
Paul, can you share all the changes you had to do, so that we can update
the docs? Or is the line above the only one you had to change?
A direct change to the source file (
https://github.com/qgis/QGIS-Documentation/edit/master/source/docs/pyqgis_developer_cookbook/authentication.rst)
with a pull request for merging would be the most practical way but we'd
also welcome changes within a text-like file or in this thread.
Thanks,
Harrissou
The only trouble is that the getCapabilities statement fails and no layer
> is added.
> Does anyone know how I can see whether the AuthManager attempted to expand
> the authcfg and send credentials as I suspect it didn’t in my case?
> Sorry if this email is too much along the developer lines for this mailing
> list but it is only plugin development rather than actual development of
> the application itself so I thought I’d try my luck.
> Thanks,
> Paul
> This e-mail and any files transmitted with it are intended solely for the
> use of the individual or entity to whom they are addressed. It may contain
> unclassified but sensitive or protectively marked material and should be
> handled accordingly. Unless you are the named addressee (or authorised to
> receive it for the addressee) you may not copy or use it, or disclose it to
> anyone else. If you have received this transmission in error please notify
> the sender immediately. All traffic may be subject to recording and/or
> monitoring in accordance with relevant legislation. Any views expressed in
> this message are those of the individual sender, except where the sender
> specifies and with authority, states them to be the views of Dorset
> Council. Dorset Council does not accept service of documents by fax or
> other electronic means. Virus checking: Whilst all reasonable steps have
> been taken to ensure that this electronic communication and its attachments
> whether encoded, encrypted or otherwise supplied are free from computer
> viruses, Dorset Council accepts no liability in respect of any loss, cost,
> damage or expense suffered as a result of accessing this message or any of
> its attachments. For information on how Dorset Council processes your
> information, please see www.dorsetcouncil.gov.uk/416433
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190725/698ad3dc/attachment.html>
