[Qgis-user] create clean knot-edge-model
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Sat Jul 27 08:02:56 PDT 2019
Btw Christoph,
If you have multiple shortest path routes to figure out (as in hundreds, millions, or billions in my case), contact me.  I am working on a python script to do that.
Nicolas
> Le 27 juill. 2019 à 10:56, Nicolas Cadieux <nicolas.cadieux at archeotec.ca> a écrit :
> Hi,
> You have multiple plugins and tools available.  You can download the following plugins:
> Geometry Checker
> Topology Checker
> Look in the main menu or in the processing tool box for the following:
> Multipart to Singlepart
> Check validity (use both methods)
> Remove duplicate vertices
> Deleted duplicate geometries
> Snap geometries to layer, (search for snap in processing)
> V.clean (break an snap,rmdangles....) see the cleaning tools.
> Some of these are unstable like check Geometries.  Try fixing one problem at a time for better stability.
> Nicolas
>> Le 27 juill. 2019 à 06:31, Christoph Jung <jagodki.cj at gmail.com> a écrit :
>> Hello at all,
>> does anybody know, if QGIS has a function to create a clean knot-edge-model from an unclean road network? PostGIS provides the function createTopology to achieve it, has QGIS an equivalent function?
>> Sincerely,
>> Christoph
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
