[Qgis-user] Plugin to perform repetetive update ?
Lars I. Nielsen, LIFA A/S lin at LIFA.DK
Fri Jun 21 01:38:58 PDT 2019
Hi Bo.
Yes, I did have a try with the Processing Modeler, but I failed to locate any function to update attributes.
It seems like it's only purpose is to generate a new (temp) layer ?
Med venlig hilsen
GIS-konsulent, FME Certified Professional
Geoinformatik
T
6313 6800
lin at lifa.dk
D
6313 6849
W
www.lifa.dk
M
2492 4866
[Beskrivelse: C:\Users\lin\AppData\Roaming\Microsoft\signatures\21x21-Images-Get-L749-l8.png]<https://www.linkedin.com/company/lifa-a-s/>
Følg os på LinkedIn og læs de seneste nyheder fra LIFA A/S
Fra: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Bo Victor Thomsen
Sendt: 20. juni 2019 23:43
Til: qgis-user at lists.osgeo.org
Emne: Re: [Qgis-user] Plugin to perform repetetive update ?
Hi Lars -
Have you tried to take a look at the processing framework ? It works appr. like the FME Desktop, but inside QGIS.
https://docs.qgis.org/testing/en/docs/user_manual/processing/index.html
If you simply want to change / edit the attribute-values of multiple records from a layer in one operation, then have a look at:
https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/attribute_table.html#editing-multiple-fields
Regards
Bo Victor Thomsen
GIS & Database specialist
AestasGIS Denmark
Den 20-06-2019 kl. 14:40 skrev Lars I. Nielsen, LIFA A/S:
Hi list.
I'm looking for a tool (plugin or otherwise) that assist me in making repetitive updates to features in a QGIS layer a little less cumbersome.
Does such a tool exist ?
Med venlig hilsen
Geoinformatik
[Beskrivelse: Beskrivelse:  C:\Users\lin\AppData\Roaming\Microsoft\signatures\284x82-Images-Get-L749-l3.gif]
T
6313 6800
lin at lifa.dk<mailto:lin at lifa.dk>
D
6313 6849
W
www.lifa.dk<http://www.lifa.dk>
M
2492 4866
CVR
20937289
[Beskrivelse: Beskrivelse:  C:\Users\lin\AppData\Roaming\Microsoft\signatures\21x21-Images-Get-L749-l8.png]<https://www.linkedin.com/company/lifa-a-s/>
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190621/eae34a3d/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190621/eae34a3d/attachment.png>
Type: image/gif
Desc: image002.gif
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190621/eae34a3d/attachment.gif>
