[Qgis-user] Table manager
carlos h carloslda256 at gmail.com
Tue Jun 25 16:49:16 PDT 2019
Thank you!!
CA
El mar., 25 jun. 2019 a las 2:09, Etienne Trimaille (<
etienne.trimaille at gmail.com>) escribió:
> Indeed Table Manager was already deprecated for some functions in QGIS 2
> IIRC.
> But it depends what you wanted to do with TableManager. If you simply
> wanted to rename fields, you can go in the vector layer properties,
> "fields" tab and rename columns there. No need to use the "refactor fields"
> algorithms, which will regenerate a new layer.
> Le sam. 22 juin 2019 à 22:36, carlos h <carloslda256 at gmail.com> a écrit :
>> Thank you!
>> AC
>> El sáb., 22 jun. 2019 a las 14:11, Bernd Vogelgesang (<
>> bernd.vogelgesang at gmx.de>) escribió:
>>> Hello!! the plugin table manager did not locate it in QGIS 3.4, has it
>>> been removed?
>>> Thank you
>>> CA
>>> Afaik, the Table Manager is dead since 3.0, and people are encouraged to
>>> use the "Refactor fields" function in the Processing Toolbox.
>>> Cheers,
>>> Bernd
>>> Qgis-user mailing listQgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190625/30591dfe/attachment.html>
