[Qgis-user] Couldn't load SIP, Python support disabled
Volker Fröhlich volker27 at gmx.at
Wed Jun 26 00:02:30 PDT 2019
That was a packaging mistake in Fedora. You can resolve it by installing
the package version 3.4.6-5 or by installing the runtime dependency I
missed: python3-qscintilla-qt5
Greetings,
Volker
Am 26.06.19 um 06:29 schrieb Ahmed Shubbar:
> I recently installed Qgis on Fedora 30. But did not get python support
> working and can see only 8 plugins available. I also tried installing
> newer Qgis 3.6.3-Noosa, but got the same errors.
> QGIS version: 3.4.6
> OS: Fedora 30
> ### Python Error 1:
> Couldn't load SIP module.
> Python support will be disabled.
> Traceback (most recent call last):
>    File "", line 1, in
>    File "/usr/lib64/python3.7/site-packages/qgis/__init__.py", line 72, in
>      from qgis.PyQt import QtCore
>    File "/usr/lib64/python3.7/site-packages/qgis/PyQt/QtCore.py", line
> 26, in
>      from PyQt5.QtCore import *
> ImportError: /lib64/libQt5Core.so.5: version `Qt_5_PRIVATE_API' not
> found (required by
> /home/ahmed/.local/lib/python3.7/site-packages/PyQt5/QtCore.so)
> Python version:
> 3.7.3 (default, May 11 2019, 00:38:04)
> [GCC 9.1.1 20190503 (Red Hat 9.1.1-1)]
> QGIS version:
> 3.4.6-Madeira 'Madeira', exported
> Python path:
> ['/usr/share/qgis/python',
> '/home/ahmed/.local/share/QGIS/QGIS3/profiles/default/python',
> '/home/ahmed/.local/share/QGIS/QGIS3/profiles/default/python/plugins',
> '/usr/share/qgis/python/plugins', '/usr/lib64/python37.zip',
> '/usr/lib64/python3.7', '/usr/lib64/python3.7/lib-dynload',
> '/home/ahmed/.local/lib/python3.7/site-packages',
> '/usr/local/lib64/python3.7/site-packages',
> '/usr/local/lib/python3.7/site-packages',
> '/usr/lib64/python3.7/site-packages', '/usr/lib/python3.7/site-packages']
> ### Python Error 2:
> An error occurred during execution of following code:
> qgis.utils.uninstallErrorHook()
>    File "", line 1, in
> NameError: name 'qgis' is not defined
> Python version:
> QGIS version:
> Python path:
> ### Python Error 3 (on closing QGIS):
> SystemError: PyEval_EvalCodeEx: NULL globals
> Python version:
> QGIS version:
> Python path:
> Qgis-user mailing list
