[Qgis-user] QGIS package broken on Ubuntu Bionic with UbuntuGIS PPA
César Augusto Ramírez Franco
caesarivs at gmail.com
Mon Mar 4 14:39:56 PST 2019
Hello,
I don't know if this is the right place to ask this, so apologies if it
isn't.
Today I updated my system through apt and the gdal package got upgraded to
2.4.0 and at the same time the qgis package got removed.
I'm using the ubuntugis-unstable PPA and the QGIS repo for ubuntugis:
deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu bionic
main # ubuntugis
deb https://qgis.org/ubuntugis bionic main # QGIS
When I try to install QGIS again, apt complains of unmet dependencies:
# apt install qgis
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
qgis : Depends: gdal-abi-2-3-0 but it is not installable
Depends: libqgis-analysis3.6.0 but it is not going to be installed
Depends: libqgis-app3.6.0 but it is not going to be installed
Depends: python-qgis (= 1:3.6.0+28bionic-ubuntugis) but it is not
Recommends: qgis-plugin-grass but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I read online that removing ubuntugis and installig from the ubuntu repo
would solve the problem but I'm relying on some ubuntugis package versions,
so what's the recommended solution? Shouldn't QGIS 3.6 be able to run with
GDAL 2.4.0?
Thanks in advance
*César Augusto Ramírez Franco*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190304/43965620/attachment.html>
