[Qgis-user] Qgis 3.6 problem
Phil Wyatt
phil at wyatt-family.com
Thu Mar 7 01:49:38 PST 2019
Can you pint us to the actual links on the web for the layers? Feel free to
send me the raster layer as well if you like if its not on the web.
Cheers - Phil
Sent: Thursday, 7 March 2019 8:42 PM
To: Phil Wyatt
Cc: Nicolas Cadieux; qgis-user at lists.osgeo.org
Subject: VS: VS: [Qgis-user] Qgis 3.6 problem
I am using Finnish open data by Finnish Transport Network and National Land
Survey of Finland. Do you want me to send you a map(png-format) witch is
raster layer? I installed Qgis 3.45 to my laptop and vector layers are seen
by Finnish Transport Network and Google Maps exported kmz-file, but when I
add map layer, it does not show map. but everything else. The order of
layers are OK- When I do the same with my main pc, it does not show any
layers.
-Jukka
_____
Lähettäjä: Phil Wyatt [phil at wyatt-family.com]
Lähetetty: 7. maaliskuuta 2019 10:23
Vastaanottaja: Jukka
Kopio: Nicolas Cadieux; qgis-user at lists.osgeo.org
Aihe: Re: VS: [Qgis-user] Qgis 3.6 problem
Can you point us to the layers? Are they open data? At least then we can
check them out and see what we can find.
Cheers - Phil,
On the road with his iPad
On 7 Mar 2019, at 6:59 pm, Jukka <Jukka at olantera.fi> wrote:
I can't figure out what is the problem. I have other projects which works
allrigt. I made a new project with same layers and properties than earlier
and is is not working. I agree that the problem is bad CRS, but I cannot
resolve it.
-Jukka
_____
Lähettäjä: Nicolas Cadieux [nicolas.cadieux at archeotec.ca]
Lähetetty: 6. maaliskuuta 2019 16:14
Kopio: Phil Wyatt; qgis-user at lists.osgeo.org
Aihe: Re: [Qgis-user] Qgis 3.6 problem
This is 99 % a bad CRS problem or a layer that has the right CRS but is
badly georeferenced. Open a background layer with a WMS or from a satellite
image from a plugin like OpenLayer. This layer should be in the right
place. Then open each layer and click zoom to layer extent (right click on
the layer in the layer panel). You will find the layer that is not
correctly georeferenced or that has an incorrect CRS.
Phil is correct when saying that in 3x, on the fly default. You may want to
select « ask what to do » if a CRS is not specified in the layer. Your
choice my be « use the project or use the default CRS ». That may throw
things off.
Nicolas
Le 6 mars 2019 à 07:08, Jukka <Jukka at olantera.fi> a écrit :
It didn't help. I checked layers CRS in both versions. I am confused,
because I have mene other projects and all are working perfect.
-Jukka
_____
Lähetetty: 6. maaliskuuta 2019 10:47
Kopio: qgis-user at lists.osgeo.org
Check the CRS and set it to the raster data and see how you go. I think V3
does on the fly projections all the time. In 2.18 you need to set that under
settings, options, CRS.
Cheers - Phil,
On 6 Mar 2019, at 6:08 pm, Jukka <Jukka at olantera.fi> wrote:
I have two version of Qgis, 3,6 and 2.18. In both version I have problems.
I started a new project and if I add raster layer map and vector layer on
map, I only can see the map or vector layer, not both. But I have older
projects that works allright. What is the problem?
-Jukka Olanterä
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190307/4f4eb070/attachment-0001.html>
