[Qgis-user] layer order
Andreas Neumann
a.neumann at carto.net
Mon Mar 11 09:47:44 PDT 2019
Hi Carl,
Glad it did the trick ;-)
Yes - this option is kind of "hidden". But I also wonder how it got
enabled?
Andreas
On 2019-03-11 17:29, Boswell, Carl A - (cboswell) wrote:
> Very nice. Thanks for the input. Don't know how that box got checked, but deselecting it did the trick. Not sure how one would track that issue down without help, but I'll certainly remember it.
> Cheers,
> C
> Carl Boswell
> 520-954-7053
> FROM: Andreas Neumann <a.neumann at carto.net>
> SENT: Monday, March 11, 2019 12:46 AM
> TO: Boswell, Carl A - (cboswell) <cboswell at email.arizona.edu>
> CC: qgis-user at lists.osgeo.org
> SUBJECT: Re: [Qgis-user] layer order
> Hi Carl,
> It might be - that by accident - you enabled the overwriting of the layer order. There is a separate "Layer Order Panel" that might be visible or not. It has a checkbox with which you can toggle which panel has preference: the "Layers" or the "Layer Order" panel.
> Reasoning behind this separation: In some more complex projects it might be desirable to structure layers into groups (hierarchically) by topics while this might contradict the actual layer order (which is a flat list). Usually, you want to first draw all polygon layers, then line layers on top, followed by points. This might not match the grouping defined in the Layers panel.
> So go to "View" --> "Panels" --> "Layer Order" and see if you enabled the "Control rendering order" checkbox. If yes, deactivate and your layers should be ordered like defined in the "Layers" panel.
> Hope this helps,
> Greetings,
> Andreas
> On 2019-03-11 04:02, Boswell, Carl A - (cboswell) wrote:
>> Up until now the layers listed were displayed in the map in a hierarchy defined by their position in the list, i.e. the one above in the list would overwrite the symbols of one below when the coordinates were the same. All of a sudden the order seems to be by date, meaning that layers that were added earlier overtake precedence over those added later, regardless of their order in the list. I can find no "switch" that can change this problem. This seems to apply whether the layer is a vector file or imported from a .csv file. Any help would be appreciated.
>> Thanks,
>> C
>> Carl Boswell
>> 520-954-7053
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user [1]
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user [1]
Links:
[1] https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190311/2b29febf/attachment.html>
