[Qgis-user] QGIS error & F29
Max Pyziur
pyz at brama.com
Mon Mar 11 15:15:46 PDT 2019
Greetings,
My use of QGis Desktop is occassional; when I do use it, I construct layers
using PostGIS & PostgreSQL.
The key component that facilitates this in QGis is a Python plugin called DB
Manager.
When I started Qgis today, there was an error message that appeared something
like this:
Couldn't load PyQGIS. Python support will be disabled.
File "", line 1, in
File "/usr/lib64/python2.7/site-packages/qgis/gui/__init__.py", line 27, in
from qgis._gui import *
RuntimeError: the PyQt4.QtCore module failed to register with the sip module
Python version:
2.7.15 (default, Oct 15 2018, 15:26:09)
[GCC 8.2.1 20180801 (Red Hat 8.2.1-2)]
QGIS version:
2.18.20 'Las Palmas', exported
After clicking away the error away, the existing layers that I had built using
PostGIS/PostgreSQL were still available in my key critical project.
However, when I went to look for DB Manager, it wasn't available.
After some searching, I upgraded to QGIS 3.6 from a non-Fedora repository (the
guidance is here:
https://stackoverflow.com/questions/53716778/the-pyqt4-qtcore-module-failed-to-register-with-the-sip-module)
and now I have access to the DB Manager functionality.
Is the Fedora/QGis community aware of this issue?
Thanks!
Max Pyziur
pyz at brama.com
