[Qgis-user] Filegeodatabase editing
Rick Rupp
palousegeo at outlook.com
Mon Mar 18 10:55:41 PDT 2019
Hi Tyler,
I can create, edit and save to fileGDB with QGIS 3.6.0 (OSGEO4W).
-Rick
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> on behalf of Tyler Veinot <tylerkveinot at gmail.com>
Sent: Monday, March 18, 2019 8:18:36 AM
To: Antongeo76
Cc: QGIS User List
Subject: Re: [Qgis-user] Filegeodatabase editing
Thank you for the reply but I think you might be refering to a Personal Geodatabase, those need an ODBC driver and cannot be edited in QGIS. A Filegeodatabase on the other hand can be edited directly in 2.18.x using the OGR Filegeodatabase driver that can be installed using the advanced options in the OGR installer; the issue of not being able to edit is recent. Last week I could edit, this week I cannot.
I did a clean install of the QGIS3 application using the OSGeo Installer and the editor is working using the OGR filegeodatabase drive but when I select save edits I get " OGR error creating feature -2: Failed at writing Row to Table in CreateFeature. (The user does not have permission to execute the operation.)"
I noticed all my file geodatabases are showing a "read only" attribute that will not go away. I can still edit them in ArcMap but nothing else. I checked for *.lock files and removed them as well. Tyler
On Mon, Mar 18, 2019 at 11:52 AM Antongeo76 <antoviscomi at gmail.com<mailto:antoviscomi at gmail.com>> wrote:
Tyler Veinot-2 wrote
> Hi All;
> Has anyone had issues editing filegeodatabases in QGIS?
> In 2.18X I was editing file geodatabase data painlessly but since QGIS LTR
> went to 3.4.x and switched over I get an error on saving (you do not have
> permissions to edit this data). I tried running QGIS as administrator and
> I
> tried reinstalling 2.18.x but now 2.18.x will not even give me the option
> to start editing, the pencil is greyed out.
> I uninstalled the filegeodatabase drive and installed the
> filegeodatabase-dev drive and now the oencil icon is greyed out in 3.4.x
> and 3.6.x.
> Has this happened to anyone else before? How did you resolve it?
> Tyler
> Qgis-user mailing list
> Qgis-user at .osgeo
HI tyler,
Yes I use currently .gdb in QGIS but the ODBC drivers are read only then I
don't be able to directly editing .gdb I save te feature I need to edit in
.shp then I can edit It
Regards
Antonio
Antonio
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190318/6e385752/attachment.html>
