[Qgis-user] how to fix the raster calculator
matteo
matteo.ghetta at gmail.com
Thu Mar 21 02:33:58 PDT 2019
Hi Maixent,
> Hi all,
> I'm using a QJIS 3.4 under window 10.
> I have issue with the raster calculator tool located in raster analysis
> section of the processing tool.
> After calculations the output layers are not visible no matter the data
> i'm using.
> I've already uninstall and reinstall the software and it is still doing
> the same thing.
> How could I fix it?
> Thanks for your advices
is the result not visible or does it have "strange" values? If so, try
to go in the layer style panel and change the min and max values
Cheers
Matteo
